Topic "Synchronize -mirror took 3 runs to complete"
3K
I am synchronizing my test site which contains ~72GB. The script is show below. It took me 3 times to run to be able to fully download the files. On the first run, it downloaded 98%. On the second run, 99%, then on the third run, 100%. During download, it shows often that it's disconnected from the server or lost connection?
winscp.com /script="syncScript.txt"
syncScript.txt:
option batch continue
option reconnecttime 2
open ftp://.....
option transfer automatic
synchronize -mirror local "C:\Mirror_Site" "/"
close
How can I improve it? Thanks.
Please attach a full log file showing the problem (using the latest version of WinSCP) for all runs.
3K
I'm attaching the log file as private. I noticed that the lost connections is every minute or 2.
Thanks.
synclog-2015-02-05 10-32-01-reduced.rar (5.46 MB) Private file
Description: The original txt file is 391mb. I deleted many lines in the middle, now when compressed, it's now 5.59mb.
"for all runs" please. Or at least for any two consecutive runs (where the latter run synchronizes the same files again).
3K
It seems some files were downloaded again. I checked their XML log, searched 6 filenames randomly and 4 were re-downloaded.
I've also other batch sync using mirror command that after few months that I re-run them, it downloads all the files again.
Regards,
Sorry, I do not understand your comment.
I asked you for a logs from two consecutive runs (where the latter run synchronizes the same files again). I got just one log from you. I cannot see from one log what files were downloaded again.
3K
I'm going to regenerate the log files. I've deleted all the files and run again the batch sync. However, it will take 2 days to complete this. Then, I will post the txt and xml logs.
Regards,
3K
Hi Martin,
I am posting the Text and XML log files. I randomly checked some downloaded files on the first XML and they are present again on the second XML.
Some files downloaded twice:
C:\ITU\ITU_Mirror_Site\ITU_Publications\ITU_Menu.html
C:\ITU\ITU_Mirror_Site\ITU_Publications\dms\pages\itu-t\rec\g\T-REC-G.1080.xml
C:\ITU\ITU_Mirror_Site\ITU_Publications\dms\pages\itu-t\rec\g\T-REC-G.108-200309-I!Amd1.html
C:\ITU\ITU_Mirror_Site\ITU_Publications\dms\pages\itu-t\rec\g\T-REC-G.1091-201410-P.xml
C:\ITU\ITU_Mirror_Site\ITU_Publications\dms\pay\itu-t\rec\e\T-REC-E.502-198811-S!!ZWD-E.zip
FYI. I couldn't post the second log file as it's the 4th file.
Regards.
synclog-2015-02-18 10-19-18 - Copy.rar (8.33 MB) Private file
Description: first text log file.
syncxml-2015-02-19 08-14-11.rar (444.5 KB) Private file
Description: second xml log file.
syncxml-2015-02-18 10-19-18.rar (757.14 KB) Private file
Description: first xml log file.
3K
Hello Martin,
In case you need the second log file, I have uploaded it here. The original file size is 328mb, so I deleted many lines in the middle and compress it. The first log file is around 370mb. FYI.
Regards.
synclog-2015-02-19 08-14-11 - Copy.rar (7.81 MB) Private file
Description: The second log file.
Thanks for the logs!
3K
Hi Martin,
Thanks, however I could not find your email with a debug version of WinSCP. Is it possible to attached it here as private file? Or otherwise, resend it again to my email.
Regards,
I've re-sent it.
