Topic "Fail in VBScript, VBA (untyped), work in VBA (typed), VB.NET"
usa
Some methods of the COM objects fail in VBScript and VBA (with untyped variables), but work in VBA (with typed variables) and VB.NET.
What's wrong? I need to make it work in VBScript.
The VB.NET code works perfectly:
Imports System
Imports WinSCP
Module Module1
    Sub Main()
        Dim sessionOptions As SessionOptions
        Dim session As Session
        sessionOptions = CreateObject("WinSCP.SessionOptions")
        sessionOptions.Protocol = Protocol.Ftp
        sessionOptions.FtpSecure = FtpSecure.Implicit
        sessionOptions.HostName = "***"
        sessionOptions.UserName = "***"
        sessionOptions.Password = "***"
        session = CreateObject("WinSCP.Session")
        session.Open(sessionOptions)
        session.SynchronizeDirectories(SynchronizationMode.Local, "***", "***", False)
    End Sub
End Module
This VBA code also works perfectly:
Option Explicit
Sub Main()
        Dim sessionOptions As sessionOptions
        Dim session As session
        Set sessionOptions = CreateObject("WinSCP.sessionOptions")
        sessionOptions.Protocol = Protocol_Ftp
        sessionOptions.FtpSecure = FtpSecure_Implicit
        Set session = CreateObject("WinSCP.Session")
        session.Open sessionOptions
        session.SynchronizeDirectories SynchronizationMode_Local, "***", "***", False
End Sub
This VBA code fails:
Option Explicit
Sub Main()
        Dim sessionOptions ' <-- !!! Removed type declaration
End Sub
It says:
Invalid procedure call or argument
at the following statement:
This VBA code also fails (when removing BOTH the declarations, the error message is the same):
Option Explicit
Sub Main()
        Dim session ' <-- !!! Removed type declaration
End Sub
It says:
Object doesn't support this property or method
VBScript code ALWAYS fails:
<job>
   <reference object="WinSCP.Session" />
   <script language="VBScript">
   Option Explicit
        Dim sessionOptions
        Dim session
        Set sessionOptions = CreateObject("WinSCP.SessionOptions")
   </script>
</job>
It says:
Module1.wsf(19, 10) Microsoft VBScript runtime error: Object doesn't support this property or method: 'SynchronizeDirectories'
Twisted Evil Twisted Evil Twisted Evil
Not sure about the typed/untyped issue. I'm not a VB/VBA expert.
But the problem with SynchronizeDirectories is fixed already in the latest beta/RC version.
See http://winscp.net/tracker/show_bug.cgi?id=1136
usa
Thanks, it works also in scripting version of Visual Basic now.
