Topic "Filemask date time problem"
When I use the file mask with a date and time nothing transfers
my file mask is as follows
transferOptions.FileMask = "*.xml<=" + strTimeMask ;
when the above translates to *.xml<=2015-02-04 all files < or = are transferred.
when the above translates to *.xml<=2015-02-04 03:27:11 nothing is transferred.
I think it has something to do with the space between the time and date but do not know how to resolve this problem.
thanks for any help
