Topic "WebDAV auth faild with proxy"
Burgess
Please help me...
failed.log (17.01 KB) Private file
Description: (none)
Are you able to connect with any other WebDAV client? E.g. CyberDuck? Can you attach it's log file?
CarotDAV is ok.
CarotDAV is ok.
http://rei.to/carotdav_en.html
Burgess
CarotDAV is ok,but it show a tips ca is expired,and I press the Ignore button.
So,I think maybe the ca is expired,and winscp is failed.
Can you ignore the ca expired?Or show me a tips,than I can press the ignore button too.
That's not the case. You have already set WinSCP to ignore the certificate errors:
Quote:
. 2015-01-28 12:18:51.876 ssl: Match common name 'xxx.com' against ''
. 2015-01-28 12:18:51.876 Identity match for '': bad
. 2015-01-28 12:18:51.876 ssl: Match common name 'xxx.com' against 'xxx.com'
. 2015-01-28 12:18:51.876 Identity match for 'xxx.com': good
. 2015-01-28 12:18:51.877 Verifying certificate for "xxx" with fingerprint 66:68:aa:8c:65:9e:58:bb:9f:9f:78:11:9d:29:11:db:d4:e1:54:aa and 08 failures
. 2015-01-28 12:18:52.213 Certificate for "xxx" matches cached fingerprint and failures
Burgess
Request To nws.neusoft.co.jp
> PROPFIND /nws/zenrin_db/ HTTP/1.1
> User-Agent: Rei.WebDAV/1.5.5
> Depth: 1
> Depth: 1
AuthorizationMethod = Negotiate
<HTTP/1.1 207 Multi-Status
< Transfer-Encoding: chunked
< Content-Type: text/xml
< Date: Wed, 25 Feb 2015 05:12:42 GMT
< Server: Microsoft-IIS/6.0
< X-Powered-By: ASP.NET
< [MESSAGEBODY LENGTH:10143]
Is more verbose logging possible? There's no mention of proxy at all.
