Topic "Server refused to start a shell/command"
rukfa
Hi there! I just can't get this darn thing to work! I need to download files from folder, check if they all have been transferred, then delete if they have. I've tried using session.GetFiles("folder","folder",true,null), but this deletes whole folder which is bad. I've also tried using session.RemoveFiles, but it just won't delete files one by one on the remote server. Now I'm trying to use session.ExecuteCommand, but the following problem arises. I'm using .ppk private key to authenticate with server, and for SFTP I use CORE FTPServer. Please HELP! Also, there is no option on the server to allow shell/command.
Authentication failed.Exception: Server refused to start a shell/command
Inner exception: WinSCP.SessionRemoteException: Authentication log (see session log for details):
Using username "faruk".
Authenticating with public key "rsa-key-20150211".
Log from server:
[20150211 13:39:43] [xxx.xxx.xx.xx] connecting
[20150211 13:39:43] [xxx.xxx.xx.xx] connected
[20150211 13:39:44] [xxx.xxx.xx.xx] user (faruk) granted access
[20150211 13:39:44] [xxx.xxx.xx.xx] connecting
[20150211 13:39:44] [xxx.xxx.xx.xx] connected
[20150211 13:39:46] [xxx.xxx.xx.xx] user (faruk) granted access
[20150211 13:39:46] [xxx.xxx.xx.xx] disconnected (faruk)
Also chunk of my code:
SessionOptions options = new SessionOptions
Protocol = Protocol.Sftp,
HostName = "xxx.xxx.xx.xx",
UserName = "faruk",
Password = "xxxxxx",
SshPrivateKeyPath = @"path\priv.ppk",
GiveUpSecurityAndAcceptAnySshHostKey = true
session.Open(options);
session.ExecuteCommand("cd folder");
You probably want to do session.GetFiles("folder/*","folder\",true,null). This won't delete the folder, just the files in it.
rukfa
I know that, and that's great, and it works! Unfortunately, after I've downloaded files locally, I can't delete them using session.RemoveFiles. It works on my computer, but it won't budge on server, so I'm trying to use commands.
rukfa
Ahhh, sorry man, I've tried this approach, but it won't do the trick Sad
Just nothing happens...
rukfa
I don't know what happened to my last comment, but I wrote to say that this works! Thank you so much man, and I appreciate it!
rukfa
Are there any known issues with working with Windows Services? I'm trying to implement the same thing using Windows Service application, and it won't copy files.
No.
