Topic "Script Synchronize Issue"
xenos
Hi there,
I have a local path from where the (specific type) files (test1, test2, test4 ==> all .txt), I want to be ftp-ed to the remote folder. I use a script as the below:
option batch abort
open ftpuser@ipaddress
synchronize remote -mirror -transfer=binary -resumesupport=on -filemask="*.spf; *.txt; *.md5" D:\temp \remote
The problems are:
*no matter if the files are already at the destination foler, it keeps overwriting then which is not accepted (see below log).
*if I delete a file at source folder, it doesn't get deleted at the destination folder
Any idea? Rolling Eyes Question
. 2015-02-13 15:48:57.962 test1.txt;-;3;2015-02-13T13:47:00.000Z;"" [0];"" [0];---------;0
. 2015-02-13 15:48:57.962 test2.txt;-;5;2015-02-13T13:47:00.000Z;"" [0];"" [0];---------;0
. 2015-02-13 15:48:57.962 test4.txt;-;6;2015-02-13T13:47:00.000Z;"" [0];"" [0];---------;0
. 2015-02-13 15:48:57.994 Local file 'D:\temp\test1.txt' [2015-02-13T13:37:17.360Z] [3] is modified comparing to remote file '\remote/test1.txt' [2015-02-13T13:47:00.000Z] [3]
. 2015-02-13 15:48:57.994 Local file 'D:\temp\test2.txt' [2015-02-13T12:26:00.000Z] [5] is modified comparing to remote file '\remote/test2.txt' [2015-02-13T13:47:00.000Z] [5]
. 2015-02-13 15:48:57.994 Local file 'D:\temp\test4.txt' [2015-02-13T13:17:52.413Z] [6] is modified comparing to remote file '\remote/test4.txt' [2015-02-13T13:47:00.000Z] [6]
< 2015-02-13 15:48:57.994 Script: Synchronizing...
xenos
I resolved the deletion part with -delete, but the main issue remains.
xenos
Just for the record, I found the answer, which is (in case someone needs it):
synchronize remote -delete -transfer=automatic -resumesupport=on -filemask="*.spf; *.txt; *.md5" D:\temp \remote
To find the root cause, please attach complete logs of two consecutive runs.
