Topic "Downloading only specific files with command script"
jericho2
First time poster here. I am new to scripts so bear with me. I am trying to edit a script that someone else wrote who used to work here. The problem I am having is that one of the ftp sites has changed and I need to set it up to download file from the new site. In this new site the folder my files are in has a sub folder with archives of past files (its a weekly radio show with audio files) What I need is for only the current week's files to be downloaded and NOT the sub folder.
Here is the command I have currently have.
cd "/home/nrtsyndication/nrtsyndication.com/syndication/Christian_Music_Rewind/"
This command successfully downloads all the files within that subfolder. However there is another folder within the "Christian_Music_Rewind" folder that has large archive files. How can I change this command so it only downloads the audio files within the this specific sub folder and not the other folder another step down?
The cd command does not transfer anything. It changes a current remote working directory only.
You probably have get command later. Add -filemask="|*/" to that to exclude all subfolders.
See http://winscp.net/eng/docs/faq_script_non_recursive
jericho2
Here is the entire script that relates to this ftp download. Maybe someone can tell me what I need to do to ignore any folders below the current working directory.
open cmr
cd "/home/nrtsyndication/nrtsyndication.com/syndication/Christian Music Rewind/"
synchronized local y:\CMR\
close
jericho2
So on the last line of my script would this give me what I want to accomplish?
synchronize local y:\CMR\-filemask="|*/" *
jericho2
I'm getting an error with this line
Can someone tell me what I need to change to make it work?
There has to be a space between synchronize command parameters and the -filemask switch:
synchronize local y:\CMR\ -filemask="|*/"
