Topic "put -delete \\myshare\fullpath1\*[.]* /fullpath2/"
usa
In a local directory named "\\myshare\fullpath1\", I've got:
1) A regular file named "test.txt".
2) A subridectory named "subdirectory".
uploads nothing, but should upload "test.txt" only.
put -delete \\myshare\fullpath1\*.* /fullpath2/
uploads both the file and the directory, and this is the expected behaviour.
So, how do I upload files only?
It's OK to upload only files with extensions.
PS:
Windows 7 x64
WinSCP, Version 5.5.6 (Build 4746)
Runs from 64-bit cscript.exe, VBScript.
usa
PS: The latest Version 5.7 (Build 5125) has this issue too.
I've never realized it could be used like that Smile
OK, added to the tracker:
http://winscp.net/tracker/show_bug.cgi?id=1283
See http://winscp.net/eng/docs/faq_script_non_recursive
usa
I am glad to surprise you Smile
Do you mean that in order to transfer all the files without directories I should transfer their parent directory non-recursively?
usa
Nevermind. I've just understood what you mean.
I actually got completely confused. The dot has a special function in operation masks only, not in file masks and moreover this is a local file mask, which does not even support the set-syntax []. So WinSCP behaves as designed.
I have updated respective comment in put command documentation:
Quote:
The Windows wildcard supports * and ? only. If you want to use a full syntax of file masks, use a -filemask switch.
http://winscp.net/eng/docs/scriptcommand_put#fn1
usa
Thanks!
