Topic "WebDAV with untrusted SSL cert from .Net"
semery
WinSCP version: 5.7 (https://winscp.net/download/winscp570automation.zip)
I am trying to connect to a WebDAV server with a self-signed certificate using the .Net assembly. I can connect to the same server with the WebDAV protocol on a different port (and with the WinSCP GUI) without SSL but I can't figure out the correct options to set to get SSL working.
If I don't supply the server's host certificate fingerprint, I get the error (as expected):
WinSCP.SessionRemoteException: Server certificate verification failed: certificate issued for a different hostname, issuer is not trusted ---> WinSCP.SessionRemoteException: Connection failed.
If I supply the certificate fingerprint with SessionOptions.TlsHostCertificateFingerprint, I get the error:
System.ArgumentException: SessionOptions.TlsHostCertificateFingerprint or SessionOptions.GiveUpSecurityAndAcceptAnyTlsHostCertificate is set, but SessionOptions.FtpSecure is FtpSecure.None.
So then if I set SessionOptions.FtpSecure to FtpSecure.Implicit, I get the error:
System.ArgumentException: SessionOptions.FtpSecure is not FtpSecure.None, but SessionOptions.Protocol is not Protocol.Ftp.
Is there anything else I can try?
That's a bug, will fix it.
Meanwhile, you can download source code of WinSCP and modify the check in Session.SessionOptionsToOpenSwitches.
Instead of
if (sessionOptions.FtpSecure == FtpSecure.None)
use
if ((sessionOptions.FtpSecure == FtpSecure.None) && !sessionOptions.WebdavSecure)
https://winscp.net/tracker/show_bug.cgi?id=1284
I'm sending you an email with a development version of WinSCP to address you have used to register on this forum.
semery
Dev version works great! Thanks!
fvboegeld
I'm having the same issue with SSL webdav
Can i also give this dev version a try?
Thanks!
Frederik
Sent.
fvboegeld
Its working perfect now!
Frederik
kyle@...
Instead of
use
Hi, can I have this version please.
Just download the latest version, this has been fixed while ago:
Peterpan
I can't find the latest version to download. I went to download link (https://winscp.net/eng/download.php#download2), but that is the version modified on 6/3/2016, which is before the fixed one.
Please help.
Please help.
No idea what you mean. The bug was fixed in 5.7.1, which was released on 2015-03-25 (over a year ago). The current stable version is 5.7.7, released on 2016-03-06.
