Topic "Automatic modification of filenames is not enough"
Georg
The Replace ‘\:*?’ checkbox enables automatic modification of filenames to match Windows requirements. This is not enough. Some filenames contain a x05 character that is not replaced and the Transfer failes. A x05 should be deleted (i. e. replaced by nothing).
20150226183609.log (124.54 KB) Private file
Description: File: '/DataFiles/(here is a x05)Was gibt es Neues¿ Highlights 2014 2015-01-17 04-30.rec'
Georg wrote:
Some filenames
What files?
Georg
The description of the log file means: File names that contain "Highlights" contain a x05 before "Was".
I understand that.
I just wonder if that's some convention; or someone just done a stupid mistake of putting 0x05 into a file name.
Georg
It is a convention, see ETSI EN 300 468, page 114, chapter A.2 http://www.etsi.org/deliver/etsi_en/300400_300499/300468/01.14.01_60/en_300468v011401p.pdf
OK, I see. But, but it's encoding control character. WinSCP expects the server to use either UTF-8 (prevalent today) or the same encoding as local Windows system. It does not support any other encoding, even those more widely used, than the one you refer to (never header of that before).
