Topic "Error Element "cwd" not found in the log file"
gaurav245
i am facing an issue while trying to open a session.
The error is that "Element "cwd" not found in the log file".
{WinSCP.SessionLocalException: Element "cwd" not found in the log file
at WinSCP.CustomLogReader.WaitForNonEmptyElement(String localName, LogReadFlags flags) in D:\winscp570source\dotnet\Internal\CustomLogReader.cs:line 100
Protocol = Protocol.Sftp,
HostName = "ftp", //hostname e.g. IP: 192.54.23.32, or mysftpsite.com
UserName = "abc",
Password = "12345",
PortNumber = 22,
SshHostKeyFingerprint = "ssh-rsa 1024 ff:22:8d:cb:44:3f:88:75:73:6d:9a:55:72:bb:b8:a1"
session.DebugLogPath = "D:\\sftpLog\\WinSCPnet.dll.CodeAnalysisLog.xml";
session.DisableVersionCheck = true;
session.Open(sessionOptions); //Attempts to connect to your sFtp site
Can you please point to the direct direction or let me know what am i missing?
Regards,
Gaurav Sachdeva
Please attach full session and debug log files showing the problem (using the latest version of WinSCP).
To generate log files, set Session.SessionLogPath and Session.DebugLogPath. Submit the logs with your post as an attachment. If you do not want to post the log publicly, you can mark the attachment as private.
etutorcity
Is there a solution to this Error Element "cwd" not found in the log file? I have this error when trying to open the Session. Please advise. Thanks.
The same answer as above.
Jahn_Hlsi
I had the same error : "cwd" not found in the log file
the problem was with the Installed winscp version, I have replaced the winscp.exe from the .NET assembly / COM library and my problem was solved,
The version of C:\Program Files (x86)\WinSCP\winscp.exe (5.5.5.0) does not match version of this assembly C:\Program Files (x86)\WinSCP\WinSCPnet.dll (5.7.3.0).
You can disable this check using Session.DisableVersionCheck (not recommended).
