Topic "SSL certificate support for FTPS"
faruxx
Will you add ssl cert support? I can't add our certs for connection.
I can add other ftp client, but i dont want use it. winscp is best for me Cool
Description: (none)
It's a priority for the next release.
http://winscp.net/tracker/show_bug.cgi?id=921
faruxx
Thanks very much.
I have sent you an email.
I have sent you an email with a development version for testing.
faruxx
Sorry for late answer,
İ sent details with mail.
hniland
I'm busy with the same issue.
Need a Client with Certificate Authentication (and User/Password) on a FTPS connection.
Could I get a version with these options available please?
Thank,s
Henk Niland
Sent. I appreciate any feedback.
hniland
Hi, thank's
allthough I haven't recieved it yet.
If you've sent the program itself rather then a link, it is probably halted by our security scanner on the mail.
It will take some time to get it released, so I can use it.
As soon as I've got it, I will let you know if it works allright.
Greetings,
Henk.
It's just a link. I've resent it. Maybe you get this time.
yayitza
Can I get a this too? I need to connect to an FTP that requires certificate authentication.
thanks!
Sent.
clemensh
can you send it to me, too? Would be great!
By the way, when is release date für 5.8?
Thank you very much!
ch
Sent.
We do not give any dates. But it won't be soon.
johnasd@hotmail.com
Hi
I am very interested in testing the FTPS certificate functionality.
Would it be possible to receive a link to the development version?
Thanks!
John
TheDoctor
May I please get the development version with client certificate support for FTPS as well?
Thanks a lot!
Sent to both of you.
johnasd
Thank you!
One question, what would the command switch to specify the certificate file and passphrase?
See help open.
It's -clientcert and -passphrase.
Though in your build it was -clientcertificate.
I'm sending you the latest build that will match a future production version.
JMisset
Could you also give me a link to the development version? I would also very much like to try this feature.
THanks in advance!
Jasper
Sent.
JAllison
prikryl wrote:
Sent.
A vendor of ours is requiring certificate authentication. Would it be possible to send me a link to the development version to test out? Thanks so much if you can!
Sent.
clemensh
prikryl wrote:
See help open.
Can you please send me this version, too? I will need the correct console commands in future. Thanks!
JMisset
prikryl wrote:
Sent.
Thanks! Enjoying it so far Smile! Nice work.
Just one question.. Every time I set up a connection it asks me for the client certificate password. Is there a way to make WinSCP remember it?
Sent.
Did you consider saving the certificate without passphrase?
JMisset
Do you mean removing the passphrase from the certificate? Im afraid that this is not an option for me..
Why? The point of the passphrase is to have the key protected. Yet, you are willing to have WinSCP remember the password, effectively breaking this. What's the difference?
Marty
I'd also like to test certificate authentication. Could you send me a portable 5.8 dev build as well, please? (or point me to a location where I can download it myself)?
Sent.
rlstreet
prikryl wrote:
Sent.
ebstc
My I have a copy too?
Sent.
jdantzler
I'd like to test it out too if possible? Thanks.
Sent.
Marty
What kind of certificate and private key format is WinSCP (version 20150710r) expecting?
When I try it with openssh generated keys, I get the following:
winscp> open sftp://marty@10.0.0.2 -clientcert=G:\Keystore\client_key-cert.pub -privatekey=G:\Keystore\client_key
Searching for host...
Connecting to host...
Authenticating...
Unable to use key file "G:\Keystore\client_key" (OpenSSH SSH-2 private key)
Using username "marty".
Disconnected: No supported authentication methods available (server sent: publickey)
Authentication failed.
The client certificates are for TLS/SSL (FTPS, WebDAVS), not for SSH/SFTP.
For SSH/SFTP, you use private keys, which WinSCP always supported (-privatekey).
You just have to convert the key to .ppk format.
Use PuTTYgen:
https://winscp.net/eng/docs/ui_puttygen
Marty
I'm trying to make an SFTP connection with a server signed client certificate.
I've already tested it, and it works on Linux with:
sftp -i <client_key> marty@10.0.0.2
The Linux sftp client expects the following naming convention in order for the client to pick up the certificate and its complementary private key:
<client_key> (private key)
<client_key>.pub (public key)
<client_key>-cert.pub (CA signed public key)
How does it work with WinSCP (version 20150710r)?
I expect it will be needing access to the certificate and its private key.
How do I have to supply those?
(BTW The SFTP server only allows authentication with client certificates.)
That's a proprietary extension of OpenSSH server.
http://cvsweb.openbsd.org/cgi-bin/cvsweb/~checkout~/src/usr.bin/ssh/PROTOCOL.certkeys
WinSCP does not support this.
There are no client certificates in proper SSH.
Marty
What a pity. It works like a charm.
I read the following:
http://www.differencebetween.net/technology/difference-between-ssh-and-ssl/ wrote:
SSL means “Secure Sockets Layer”. Many protocols — like HTTP, SMTP, FTP, and SSH ‘“ were adjusted to include the support of SSL. Basically, it works as a tier in a certain protocol to provide cryptographic and security functions.
The combination of certificates and SSH is very powerful. There is no need any more for users to copy their public keys to the server. The Certificate issuer (CA / signer) can make the certificate valid for a limited time period. SSH options can be allowed or disallowed per certificate. It's great.
BCH
I also am working on a particular use case with a need for client certs on implicit FTPS connections.
If possible, I'd like to test the 5.8 version for our particular case : cert and its key are located either on a smart-card, or a USB dongle.
Thanks a lot !
WinSCP supports file certificates only.
Anyway, I have sent you an email with a development version of WinSCP to address you have used to register on this forum.
ftpuser
Hi Can I have the dev version also as I have a need for this via c#. Thanks
Sent.
Tom VS
Hi prikryl,
Can you please send me the 5.8 dev version too for the same reason FTPS with certs.
Tom
Sent.
ljakobs
Sent.
