Topic "Errors when try to compile"
Michel68
I have errors when i'am trying to compile the WinSCP project in C++ Builder XE7 (complete installation)
I tried to compile with Net Framework 3.5 and 4, 32 and 64 bits too, i'm running windows 8 64bits.
I attach the errors output on this post.
Have you any ideas on this problem ?
Regards,
Capture d’écran 2015-03-06 à 17.02.21.png (20.92 KB)
Description: (none)
Tonioa310
Hi all,
I have the same problem, even using Embarcadero XE6.
In fact I just would like to modify the little part of the code that prints the transfer file progress.
Instead of updating the line of the file in progress, I would like to display a new line with the current progress.
Is ther any way to perform that without recompiling the project ?
Thank you anyway, this soft is really awsome.
Regards
Regarding RaiseList. I haven't seen it before. It's a deprecated identifier. So maybe you have strict compiler mode set. But you should be using the same settings as we do, if you are using our project files.
Anyway, I replaced this code:
          if RaiseList <> nil then
          begin
            FSynchronizeException := PRaiseFrame(RaiseList)^.ExceptObject;
            PRaiseFrame(RaiseList)^.ExceptObject := nil;
          end;
with:
          FSynchronizeException := AcquireExceptionObject;
Though there will be lot more deprecated identifiers used, so it's unlikely this actually helps.
You can use WinSCP .NET assembly and handle Session.FileTransferProgress event.
http://winscp.net/eng/docs/library_session_filetransferprogress
Or filter \r from winscp.com output.
Tonioa310
Thank you prikryl,
I tried the tips you gave me but without success.
No big deal, I did it another way.
Thank you for your support anyway.
Best regards
