Topic "How do I set option batch abort from .Net"
K_G
Hi
How do i set
option batch abort
using C sharp .net code?
I tried the rawswetings, but does not seem to work as i thought it would.
The assembly uses option batch on mode. If you call .Check() on all "operation results" returned by Session class methods, you get an equivalent of abort mode.
See also
http://winscp.net/eng/docs/library_session#results
http://winscp.net/eng/docs/library_from_script#mode
K_G
soryr , so how do i convert
GetFiles() to use .check
as I did look at that, but does not seem to work as example is using TransferResult.
as compiling gives
'Cannont implicitly convert type 'void' to 'WinSCP.TransferOperationResult'
Hope you can help.
See
http://winscp.net/eng/docs/library_session_getfiles#csharp
or
http://winscp.net/eng/docs/library_session#results (example for .PutFiles, but it's the same for .GetFiles)
