Topic "Error: Timeout waiting for WinSCP to respond - WinSCP has no"
bach1899
I get the following error from .NET when trying to run WinSCP from a web app:
Failed: Timeout waiting for WinSCP to respond - WinSCP has not responded in time (response log file C:\Windows\TEMP\wscp10DC.0191F3F3.tmp was not created). This could indicate lack of write permissions to the log folder or problems starting WinSCP itself.
I can run it from the GUI, but when I run from the web app, it produces that error. Also on my development computer, when debugging in VS, it actually works when called from the web app, only when I publish to the production server it produces that error.
The DLL version info is:
File version: 1.2.6.5125
Product Version 5.7
The production server is running Windows Server 2012 R2 Standard.
I turned on logging, and noticed that there is no log entry when trying to call it from the web app.
fabi85@...
prikryl wrote:
hello, you will find solution to this bug,thank you very much.
kmr
Below issue happens only in production server not on staging or dev
Dev,Staging and prod both are on Window 2012 R2 with .Net Framework 4.5 & 4.0
Ftp Get Error: Timeout waiting for WinSCP to respond - WinSCP has not responded in time (response log file C:\Windows\TEMP\wscp09D4.00EE499F.tmp was not created). This could indicate lack of write permissions to the log folder or problems starting WinSCP itself. at WinSCP.Session.CheckForTimeout(String additional) at WinSCP.Session.Open(SessionOptions sessionOptions) at Lecorpio.BLL.ETIF.Ftp.Providers.WinSCPBaseFtpProvider.Get(FTPPortInfo ftpPortInfo, String localFileName) at Lecorpio.BLL.ETIF.Ftp.FtpClient.Get(Guid integrationPortId, String localFileName)Transport Type: SFTP
What version of WinSCP?
