Topic " stops working after transfering some file"
Hello, i use, version
I call with such command: /script="c:\winscp_script.txt"
The contents of winscp_script.txt is:
open ftps://client_bases:some_address_and_password990 -implicit
option echo on
put c:\test_ftp\* -delete
Problem: stop working after transering file unipatch.txt (in the attachment). Please tell me the reason of the problem, and how i can resolve it?
unipatch.txt (167 Bytes) [Download]
Description: (none)
