Topic "Copying files from remote side failed - Can't open file"
murrometz
Hello! I'm trying to automate downloading backups from my server.
I use Task Scheduler in Windows 7.
Code of script
option batch on
open ftp://...
option transfer binary
get -resume bak.sh С:\backup\new\
What I get
< 2015-03-10 18:08:35.182 150 Here comes the directory listing.
. 2015-03-10 18:08:35.183 drwx------    4 1003     600          4096 Mar 10 03:18 .
. 2015-03-10 18:08:35.183 drwx------    4 1003     600          4096 Mar 10 03:18 ..
. 2015-03-10 18:08:35.184 -rw-------    1 1003     600          1342 Mar 08 21:46 bak.sh
< 2015-03-10 18:08:35.206 226 Directory send OK.
. 2015-03-10 18:08:35.206 Directory listing successful
. 2015-03-10 18:08:35.206 bak.sh;-;1342;2015-03-08T18:46:00.000Z;"1003" [0];"600" [0];rw-------;0
. 2015-03-10 18:08:35.207 File: '/bak.sh' [2015-03-08T18:46:00.000Z] [1342]
. 2015-03-10 18:08:35.207 Copying "/bak.sh" to local directory started.
. 2015-03-10 18:08:35.207 Binary transfer mode selected.
. 2015-03-10 18:08:35.207 Starting download of /bak.sh
> 2015-03-10 18:08:35.208 TYPE I
< 2015-03-10 18:08:35.236 200 Switching to Binary mode.
> 2015-03-10 18:08:35.236 PASV
< 2015-03-10 18:08:35.261 227 Entering Passive Mode (188,225,16,121,118,122).
. 2015-03-10 18:08:35.261 Can't open file 'С:\backup\new\bak.sh'.
. 2015-03-10 18:08:35.261 Copying files from remote side failed.
* 2015-03-10 18:08:35.261 (ExtException) **Can't open file 'С:\backup\new\bak.sh'.**
* 2015-03-10 18:08:35.261 Copying files from remote side failed.
. 2015-03-10 18:08:35.261 Asking user:
. 2015-03-10 18:08:35.261 Error transferring file '/bak.sh'. ("Can't open file 'С:\backup\new\bak.sh'.","Copying files from remote side failed.")
< 2015-03-10 18:08:35.261 Script: Error transferring file '/bak.sh'.
< 2015-03-10 18:08:35.262 Script: Can't open file 'С:\backup\new\bak.sh'.
< 2015-03-10 18:08:35.262 Copying files from remote side failed.
* 2015-03-10 18:08:35.263 (EScpSkipFile) Error transferring file '/bak.sh'.
* 2015-03-10 18:08:35.263 Can't open file 'С:\backup\new\bak.sh'.
* 2015-03-10 18:08:35.263 Copying files from remote side failed.
. 2015-03-10 18:08:35.263 Script: Failed
> 2015-03-10 18:08:35.263 Script: exit
. 2015-03-10 18:08:35.263 Script: Exit code: 1
. 2015-03-10 18:08:35.265 Disconnected from server
The script doesn't create any file.
Is it rights or what ...
Can you help me please! I'm new to winscp scripting and I don't get what's going wrong.
Thank you.
murrometz
Any help would be appreciated
murrometz
ok.
Системе не удается найти указанный путь
is translated as
The system cannot find the path specified
log.txt (8.35 KB) Private file
Description: (none)
Does the target path С:\backup\new\ exist? Can the Scheduler account see/access it? Can you do lls С:\backup\new\ before the get?
murrometz
Thank you for your help!
Yes, i confused cyrillic С and latin C. They are on the same key on the keyboard.
Thank you for your program!
