Topic "Error in script - could not be renamed to target file name"
Dragan
Hello I am testing script below taken from WinSCP site but I face problem when I run that VB script. Here is the error message:
"PS C:\XXX\test> .\script.ps1
Upload of C:XXX\test\test1.xml failed: Transfer was successfully finished, but temporary transfer file
'test1.xml.filepart' could not be renamed to target file name 'test1.xml'. If the problem persists, you may try to turn
off transfer resume support."
How do I turn this off and send files as they are instead of changing them in temp?
Can you tell me what do I add to this script below and were exactly do I add it to make this script working without any errors.
Moving local files to different location after successful upload
param (
$localPath = "C:\upload\*",
$remotePath = "/home/user/",
$backupPath = "C:\backup\"
try
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
# Setup session options
$sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
$sessionOptions.HostName = "example.com"
$sessionOptions.UserName = "user"
$sessionOptions.Password = "mypassword"
$sessionOptions.SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
try
# Connect
# Upload files, collect results
$transferResult = $session.PutFiles($localPath, $remotePath)
# Iterate over every transfer
foreach ($transfer in $transferResult.Transfers)
# Success or error?
if ($transfer.Error -eq $Null)
Write-Host ("Upload of {0} succeeded, moving to backup" -f
$transfer.FileName)
# Upload succeeded, move source file to backup
Move-Item $transfer.FileName $backupPath
else
Write-Host ("Upload of {0} failed: {1}" -f
$transfer.FileName, $transfer.Error.Message)
finally
# Disconnect, clean up
$session.Dispose()
exit 0
catch [Exception]
Write-Host $_.Exception.Message
exit 1
thanks
Dragan
Dragan
Can anyone try to modify the script for me please to transfer files without adding prefix and need of renaming it again?
Much appreciated.
Dragan
See http://winscp.net/eng/docs/message_transfer_finished_could_not_rename
Dragan
Does anyone know how to turn off tmp file transfer ? I really need this urgently. Can you help?
Dragan
Hi prikryl
thanks for getting back to me. I found that info already giving me reason why this happens but I am failing to find the way to turn it off in this script. Could you please let me know how to modify the script not to rename file while sending?
thanks in advance
The answer is just a one click away:
http://winscp.net/eng/docs/ui_pref_resume#temporary
Use TransferOptions.ResumeSupport property.
http://winscp.net/eng/docs/library_transferoptions
Dragan
I have added TransferOptions.ResumeSupport to my script but I get error:
The term 'TransferOptions.ResumeSupport' is not recognized as the name of a cmdlet, function, script file, or operable p
rogram. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
Are you able to place this command in my script so that it fits with other commands? I have no much experience with scripting.
Regards
Dragan
I hope you can imagine, that we cannot help you, if you do not show us the code that produces the error.
Dragan
I have added this line to the script "$transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::off" but it still coming up with the same error:
Upload of C:\sFTP-GiB_to_MS-XB60\test\test1.xml failed: Transfer was successfully finished, but temporary transfer file
Here is the script
param (
try
try
# Connect
# Success or error?
$transfer.FileName)
else
finally
$session.Dispose()
exit 0
catch [Exception]
exit 1
How do I get rid of this error message?
You do not use the $transferOptions anywhere. And your assignment syntax is a nonsense anyway.
See for example:
http://winscp.net/eng/docs/library_powershell#example
