Topic "Synchronize - Transfer settings - File masks is not saved"
gentee
I specify File mask in Synchronize - Transfer Settings, sychronize folders successfully but FileMask is empty when I open Synchronize dialog next time. It is only in the History. I have to open Transfer Settings each time and select File Mask.
Is it feature? Is it possible to specify the default file mask somewhere in the ini file?
WinSCP: 5.7 (portable)
OS: Windows 8
gentee
The 'Use same options next time' checkbox doesn't help.
WinSCP does not have transfer settings defaults specific to a Synchronization.
You can only configure the global defaults.
Or configure a preset that you can then select on the Synchronization options dialog.
See http://winscp.net/eng/docs/ui_pref_transfer
gentee
Thank you very much. That works.
noftpanymore
I find this highly confusing as well. In the Synchronize dialog, why not change 'Use same options next time' to 'Use same options during this session', or 'Use these options until the session is exit'?
What is confusing?
noftpanymore
The fact that checking the 'Use same settings next time' box does not work as expected. Next time WinSCP is started the latest changes are gone - as you already wrote. It will keep them only when doing this in the global dialog.
So WinSCP needs to make clear that this checkbox in the Sync dialog is a 'temporary' one.
That's misunderstanding.
The Use same settings next time is not for a current session only, it's persistent. But it applies to the settings above the checkbox only. So it particularly does not preserve the transfer settings. At all, not even for a current session.
