Topic "Is this a bug ? The progress box gone daft"
50Hertz
just updated to the latest version from previous version and started to transfer files from my satellite receiver I have been using this program for ages to do this but after today's update
the pop up box window shows the two progress bars but the bottom one is full all the time green and flashes off then goes to full instantly this happens in middle of file or end regardless.
the top progress bar shows no green at all so shows no progress for 12 files 40gigs worth
the blue bar at the top shows 0% progress all the time although checking the drive files are transferring and all the numbers showing progress in this box are working fine except time shows I450,13:53:14 the i450 changes to i85 or 482 and so on
To recap top bar shows 0% progress all the time
The top whole progress shows nothing no green
The bottom progress bar flashes to full and stays there
Time left is wrong all the time it's going to take
I rebooted and no change
Regards Vincent
