Topic "Issue with -append switch and SFTP"
BrianBak
We are in the process of translating several scripts that were previously utilizing FTP in to SFTP using WinSCP.
A couple of my scripts use the append ftp command. This is supposed to be equivalent to the "put -append" command, but it is not working. It simply overwrites the existing file with information from the new file, but not the whole file.
Example:
FileA.txt
1111
2222
3333
FileB.txt
4444
5555
Command:
winscp.com /command "option batch abort" "option confirm off" "open sftp://user:password@servre/" "cd directory" "put -append FileB.txt FileA.txt" "exit"
Result:
4444
5555
3333
Any ideas?
I cannot reproduce your problem.
BrianBak
Here is the log, thanks!
Append.log (9.29 KB) Private file
Description: (none)
I have tested their server. It's just buggy. It's not only the "append" mode that does not work. Choose a different SFTP server software.
BrianBak
I was worried that would be the case... Sad
I don't have a choice of SFTP servers so it looks like I have to avoid the -append switch.
I was able to work around the issue by using a combination of get and put commands, I'm pasting my workaround here in case someone else runs in to the same issue and finds this thread, and please let me know if you see anything wrong with the code below. Thanks for your help!
REM ****************************************************
REM This code is to handle appending the new file
REM to the existing file if it exists.
echo Pulling existing file from SFTP server (if exists) and renaming to file1.txt
winscp.com /command "option batch abort" "option confirm off" "open sftp://user:password@server/" "cd DIRECTORY" "get file.txt \\server\share\file1.txt" "exit"
echo Renaming new file to file2.txt so it will append to end of file1.txt
ren \\server\share\file.txt file2.txt
echo Appending new file to existing file.
for /R \\server\share %%f in (file*.txt) do type "%%f" >> \\server\share\output.txt
echo Sending updated file back to SFTP server and changing name back to original file.txt
winscp.com /command "option batch abort" "option confirm off" "open sftp://user:password@server/" "cd DIRECTORY" "put \\server\share\output.txt file.txt" "exit"
echo SFTP completed appending file.
Thanks for sharing your solution.
