Topic "Exception with GetFiles() with Remove on Directory"
dotps1
Hello, this is my first issue i have come across with WinSCP, I am getting an error when i use the GetFiles() method and use the Remove Parameter and it is for a directory. It seems to work find when I get just a file.
Here is my set up:
WinSCP 5.7.0.0
Windows 8.1 x64 Enterprise
PowerShell V4
FileZilla FTP Server running locally.
Here is my Code:
$so = New-Object WinSCP.SessionOptions
$so.UserName = "MyUser"
$so.Password = "MyPassword"
$so.HostName = "127.0.0.1"
$so.Protocol = "Ftp"
$s = New-Object WinSCP.Session
$s.Open($so)
$s.GetFiles("./TestFolder", "C:\Local\TestFolder", $true)
And it is throwing the following error:
Quote:
Exception calling "GetFiles" with "3" argument(s): "Operation is not valid due to the current state of the object."
But, it is actually transfering the folder, and removing it from the source. And here is the FileZilla info, with no errors:
Quote:
(000120)3/20/2015 9:56:29 AM - myuser (127.0.0.1)> PWD
(000120)3/20/2015 9:56:29 AM - myuser (127.0.0.1)> 257 "/" is current directory.
(000120)3/20/2015 9:56:59 AM - myuser (127.0.0.1)> REST 0
(000120)3/20/2015 9:56:59 AM - myuser (127.0.0.1)> 350 Rest supported. Restarting at 0
(000120)3/20/2015 9:57:29 AM - myuser (127.0.0.1)> REST 0
(000120)3/20/2015 9:57:29 AM - myuser (127.0.0.1)> 350 Rest supported. Restarting at 0
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> MLST /TestFolder
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> 250-Listing /TestFolder
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> type=dir;modify=20150320135457; /TestFolder
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> 250 End
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> CWD /TestFolder/
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> 250 CWD successful. "/TestFolder" is current directory.
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> PWD
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> 257 "/TestFolder" is current directory.
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> TYPE A
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> 200 Type set to A
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> PASV
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> 227 Entering Passive Mode (127,0,0,1,223,251)
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> MLSD
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> 150 Opening data channel for directory listing of "/TestFolder"
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> 226 Successfully transferred "/TestFolder"
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> 250 CWD successful. "/" is current directory.
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> RMD /TestFolder/
(000120)3/20/2015 9:57:40 AM - myuser (127.0.0.1)> 250 Directory deleted successfully
Thanks for any help.
Please attach a full session and debug log files showing the problem (using the latest version of WinSCP).
To generate log files, set Session.SessionLogPath and Session.DebugLogPath. Submit the log with your post as an attachment. If you do not want to post the logs publicly, you can mark the attachments as private.
Also, can you see a callstack of the exception?
dotps1
here is my code:
$s.DebugLogPath = "C:\Local"
$s.SessionLogPath = "C:\Local"
$s.Open($so)
$s.Close()
i get access denied message for the debug log. I tried a few differnt locations, and i gave everyone full control to the path in the code. If i comment that out and only try to use the sessionlog, i get this:
Quote:
Exception calling "Open" with "1" argument(s): "Error occurred during logging. It's been turned off."
i will keep trying to get that to work.
here is the full error i get for the GetFiles() exception:
At line:12 char:1
+ $s.GetFiles("./TestFolder", "C:\Local\TestFolder", $true)
+ CategoryInfo : NotSpecified: (:) [], MethodInvocationException
+ FullyQualifiedErrorId : InvalidOperationException
dotps1
Sorry, i didn't know you had to actually specify a file name for the log(s). So here they are.
Thanks again.
session.log (6.49 KB) Private file
Description: session log
debug.log (34.58 KB) Private file
Description: debug log
Do you have a callstack of the exception?
dotps1
Contributor
i used the Resolve-Error function to generate this stacktrace, hope it helps.
PSMessageDetails      :
Exception             : System.Management.Automation.MethodInvocationException: Exception calling "GetFiles" with "3" argument(s): "Operation is not valid due to the current state of the object." ---> System.InvalidOperationException: Operation is not valid due to the current
                           at WinSCP.Session.GetFiles(String remotePath, String localPath, Boolean remove, TransferOptions options)
                           at CallSite.Target(Closure , CallSite , Object , String , String , Boolean )
                           --- End of inner exception stack trace ---
                           at System.Management.Automation.ExceptionHandlingOps.ConvertToMethodInvocationException(Exception exception, Type typeToThrow, String methodName, Int32 numArgs, MemberInfo memberInfo)
                           at System.Dynamic.UpdateDelegates.UpdateAndExecute4[T0,T1,T2,T3,TRet](CallSite site, T0 arg0, T1 arg1, T2 arg2, T3 arg3)
                           at System.Management.Automation.Interpreter.DynamicInstruction`5.Run(InterpretedFrame frame)
                           at System.Management.Automation.Interpreter.EnterTryCatchFinallyInstruction.Run(InterpretedFrame frame)
TargetObject          :
ErrorDetails          :
InvocationInfo        : System.Management.Automation.InvocationInfo
ScriptStackTrace      : at <ScriptBlock>, <No file>: line 1
PipelineIterationInfo : {}
MyCommand             :
BoundParameters       : {}
UnboundArguments      : {}
ScriptLineNumber      : 1
OffsetInLine          : 1
HistoryId             : -1
ScriptName            :
Line                  : $s.GetFiles("./TestFolder", "C:\Local", $true)
PositionMessage       : At line:1 char:1
                        + $s.GetFiles("./TestFolder", "C:\Local", $true)
PSScriptRoot          :
PSCommandPath         :
InvocationName        :
PipelineLength        : 0
PipelinePosition      : 0
ExpectingInput        : False
CommandOrigin         : Internal
DisplayScriptPosition :
00000000000000000000000000000000000000000000000000000000000000000000000000000000
ErrorRecord                 : Exception calling "GetFiles" with "3" argument(s): "Operation is not valid due to the current state of the object."
StackTrace                  :    at System.Management.Automation.ExceptionHandlingOps.ConvertToMethodInvocationException(Exception exception, Type typeToThrow, String methodName, Int32 numArgs, MemberInfo memberInfo)
WasThrownFromThrowStatement : False
Message                     : Exception calling "GetFiles" with "3" argument(s): "Operation is not valid due to the current state of the object."
Data                        : {System.Management.Automation.Interpreter.InterpretedFrameInfo}
InnerException              : System.InvalidOperationException: Operation is not valid due to the current state of the object.
TargetSite                  : Void ConvertToMethodInvocationException(System.Exception, System.Type, System.String, Int32, System.Reflection.MemberInfo)
HelpLink                    :
Source                      : System.Management.Automation
HResult                     : -2146233087
11111111111111111111111111111111111111111111111111111111111111111111111111111111
Message        : Operation is not valid due to the current state of the object.
Data           : {}
InnerException :
TargetSite     : WinSCP.TransferOperationResult GetFiles(System.String, System.String, Boolean, WinSCP.TransferOptions)
StackTrace     :    at WinSCP.Session.GetFiles(String remotePath, String localPath, Boolean remove, TransferOptions options)
HelpLink       :
Source         : WinSCPnet
HResult        : -2146233079
Thanks. I have responded to your email.
dotps1
Contributor
Same exception with latest version. I have attached the Log(s) and here is the stack trace:
PSMessageDetails      :
TargetObject          :
ErrorDetails          :
ScriptStackTrace      : at <ScriptBlock>, <No file>: line 13
MyCommand             :
ScriptLineNumber      : 13
OffsetInLine          : 1
HistoryId             : -1
ScriptName            :
Line                  : $s.GetFiles("./TestFolder", "C:\Local\TestFolder", $true)
PositionMessage       : At line:13 char:1
PSScriptRoot          :
PSCommandPath         :
InvocationName        :
PipelineLength        : 0
HelpLink                    :
Data           : {}
InnerException :
HelpLink       :
Source         : WinSCPnet
Session.log (7.05 KB) Private file
Description: (none)
Debug.log (34.57 KB) Private file
Description: (none)
http://winscp.net/tracker/show_bug.cgi?id=1299
