Topic "small fix for login fortunes, etc"
When connecting to ssh, I have "fortune" in my .bashrc, which prints a little fortune. However winscp chews on this, because it makes the initial packet(s) too big and complains. Trivial fix is to check the type of terminal through environment variable in script, like:
# Fix for winscp
if [ "$TERM" != "dumb" ]; then
(putty and openssh emulate xterm, should work for other clients also - try "echo $TERM" to see)
Now winscp works and I get my fortunes in putty and so on. why winscp needs to launch bash at all, I don't know, maybe weirdness in ssh protocol, hah. anyway, hope that helps someone out Very Happy
You should read F.A.Q. to learn cause of your problems and also to learn that your solution is not the right one Smile
I lose Embarassed
I always wondered the difference between .bash_profile and .bashrc, I get it now.. you learn something every day, I guess Confused
ps error message contains suggestion that .profile prints the message (the faq says .profile isn't executed for non-interactive), which made me think .bashrc and .bash_profile are the other way around. argh. maybe make it link to the faq? Smile
sorry for wasting time, delete please. Mad
