Topic "TouchPad scroll only in tree working"
SirWill
Hey,
I have currenlty the issue that I can only scroll with my TouchPad in the directory tree and not in the section. I already reinstalld WinSCP but it doesn't change anything. If I plug in a mouse I can scroll with the mouse.
Version: 5.7.1 (Build: 5235), Windows 8.1, Explorer & Commander interface
Do you mean that you cannot scroll the file list?
SirWill
Yes.
Mail send.
marchiuzz
I have bought dell xps 13(9343 version). And i have the same issue. You can not scroll with touchpad. Everything is ok with mouse.
marchiuzz
My email is: marchiu...@...
I have sent you an email with a debug version of WinSCP.
agnussmcferguss
Did anyone work out a solution to this problem? I am seeing this on my Surface Book.
I'm happy to try the debug version to try and work this out also (if required).
For what it's worth, I can see the scrollbar move when I scroll, but as soon as I stop scrolling it moves back up to top (or wherever it was positioned). The contents of the pane don't scroll with the scrollbar. It does scroll if I drag on the touchscreen.
Cheers for any advice.
agnussmcferguss
Thanks! I've sent the email Smile
Got the same problem.. Could you also send me a debug version? My email is jingtianhu2@gmail.com
Quote:
Got the same problem.. Could you also send me a debug version? My email is jingtianhu2@...
Thanks for offering a help with this problem.
Though, I've tried to debug this numerous times already. But I was never able to identify the problem. Looks like a driver issue combined with some specifics of WinSCP (specifically the VCL library).
So I do not think it's worth trying again to debug this remotely. I'd have to have obtain the problematic machine physically.
https://winscp.net/tracker/show_bug.cgi?id=1426
a2140416
I see. Thanks! For your information, the computer I have is a Toshiba Kirabook. It might be the high pixel density or the touch screen that caused the issue.
So do you have problems with touchscreen or touchpad?
a2140416
I can scroll up and down on the Touchscreen, but not with the Touchpad. Probably, scrolling with mouse is not working either (not 100% sure).
a2140416
Sorry I made a mistake. Scrolling with mouse is okay - only touchpad has the issue.
Thanks for the clarification.
