Topic "keepalives in editor / viewer"
Martin, you've mentioned somewhere on the forum that even far doesn't allow you do that in proper way are going to add some tricks to have keepalives working while editor is active, so connection with the server is not get broken...
I noticed that it keeps breaking connection in editor even with the last version of scp pluging. My qurestion: is there anything I should to do to trigger your "workaround for editor" or it wasn't implemented yet?
thanks again for such great plugin! Smile
The workaround was not implemented yet. I found it more difficult than I've expected.
