Topic "Exclude Directory"
AWimpyNiNjA
For the life of me I can't figure out how to exclude a directory from a syncronization. My code works well otherwise.
# Automatically abort script on errors
option batch abort
# Connect
open ftp://username:password@servername.webaddress.net
# Download file to the local directory X:\
synchronize local X:\
# Disconnect
close
This syncs everything up perfectly, except I want to exclude a directory called "Annotations" from the remote ftp server.
option exclude "Annotations"
does not work in this case. I can't find any really good info around the winscp website on how to do this.
synchronize local -filemask="| Annotations/" X:\
See
http://winscp.net/eng/docs/scriptcommand_synchronize
http://winscp.net/eng/docs/file_mask
AWimpyNiNjA
prikryl wrote:
That didn't work unfortunately :/.
