Topic "FileExists Does not work with FileMask"
andrewkc69
I am using the latest version of WinSCP, and I am using the .NET assemblies.
In my code (pasted below), I set the transferoptions filemask. Based on the documentation, it doesn't look like session.FileExists supports this, so I included it. My filemask is ODS*.txt.
When I run the code with the filemask in the session.FileExists, it returns false, even if the file exists. On the other hand, if I don't include the filemask (and just use the directory) it returns true if there are any files in the directory. When it runs the session.GetFiles, the transferResult returns true for transferResult.IsSuccess, even though no files were transferred. I can I check to see if a file exists in the directory, using a filemask?
 SessionOptions sessionOptions = new SessionOptions();
                    if (job.ConnectionType == "sftp")
                        sessionOptions.Protocol = Protocol.Sftp;
                        sessionOptions.GiveUpSecurityAndAcceptAnySshHostKey = true;
                    sessionOptions.HostName = job.FTPAddress;
                    sessionOptions.PortNumber = Convert.ToInt32(job.port);
                    sessionOptions.UserName = job.Username;
                    sessionOptions.Password = job.Password;
                        // Connect
                        session.Open(sessionOptions);
                        // Upload files
                        TransferOptions transferOptions = new TransferOptions();
                        transferOptions.TransferMode = TransferMode.Binary;
                        transferOptions.FileMask = job.PickUpDirectoryMask;
                        TransferOperationResult transferResult = null;
                        if (job.FTPType == "get")
                            if (session.FileExists(job.PickUpDirectory))
                                transferResult = session.GetFiles(job.PickUpDirectory, job.DropOffDirectory, true, transferOptions);
                            else
                                LogFTPStatus(job.JobId, false, "Scheduled", "Fail - File does not exist.", log);
                        else
                                transferResult = session.PutFiles(job.PickUpDirectory, job.DropOffDirectory, true, transferOptions);
                            else
                        if (transferResult != null)
                            if (transferResult.IsSuccess)
                                //The transfer can still look like a success even if no files were transfered. Not sure why
                                if (transferResult.Transfers.Count >= 1)
                                    LogFTPStatus(job.JobId, true, "Scheduled", "Success", log);
                                else if(transferResult.Transfers.Count == 0)
                            else
                                transferResult.Check();
                                LogFTPStatus(job.JobId, false, "Scheduled", "Fail", log);
                                log.WriteEntry("Failures were: " + transferResult.Failures.ToString());
                else
                    log.WriteEntry("No transfers to run");
            catch (Exception e)
                //Write the exception to the event log
                log.WriteEntry("Error in FTP Transfer: " + e);
                //Write the exception to the system log
                LogFTPStatus(job.JobId, false, "Scheduled", e.InnerException.ToString(), log);
Calling FileExists with a path to a directory tests, if the directory exists, not if files exist in the directory.
See http://winscp.net/eng/docs/script_checking_file_existence
andrewkc69
Let me make sure I understand you correctly. A method called "FileExists", which returns a bool, only checks to see if the directory exists? Then why is the method called "FileExists"? Do I need to use a method called "DirectoryExists" to see if a file inside a directory exists? I'm sorry, but that just seems like poor design to create a method that looks like it's supposed to see if a files exists, when it actually looks at the directory.
