Topic "Continue disconnecting after migration from windows to linux"
Hi everybody, since I migrate my site from a windows server to a linux one first i can reach the root directory. But when i click into a folder (whichever) this is what happened to winscp:
log:
Error ->lost connection
Timeout detected. (data connection)
After a few seconds it try unsuccessfully reconnection. For 3 or 4 times it loops like this.
Then it enter the directory, but if i want to change or upload or someother operation, it restarts with the faulty loop that i described.
I called the support of my server provider and he told me to see if i had installed the latest version of winscp. So I downloaded it. But the problem remains.
Then support asked to me to try another ftp client and I had already FileZilla. I thought it gives the same problem, but no, it worked perfectly.
So I checked: same computer, same firewall, same ftp client settings.
No way, so i decided to write here in the hope to receive some support
Thank you.
A log file from FileZilla for a comparison would help too.
Here is win scp log, I will produce the other log as soon as possible
scp.log (35.96 KB) [Download]
Description: winscp log
filezilla log (simple and complete)
filezilla_ful.txt (4.97 KB) [Download]
Description: filezilla full log
filezilla_simple.txt (3.98 KB) [Download]
Description: filezilla simple log
What version of FileZilla are you using?
I wonder why it uses LIST command instead of MLSD.
Does anything change if you force WinSCP to fallback to LIST command too?
Set both Use MLSD command for directory listing and Support for listing of hidden files to Off.
http://winscp.net/eng/docs/ui_login_ftp
FILEZILLA VERSION: 2.2.13a
Changing settings following your advice, it works well.
Just one question: could I have security problems or some other problem with these settings?
Thank you for your help prikryl
No. But you might have security problems from using 10 years old version of FileZilla (what explains why it uses LIST command).
ehehe, yes, you're right. But as I has no way to upload files over ftp and my service provider customer care told me to use alternative client, that was what i had. Really old because for years i've been using winscp leaving that version of filezilla in a folder getting dust and dust year after year.
Anyway, Why do my server not accept MLSD command? I thing there is some problem with server settings (that i cannot controll).
No idea.
