Topic "Session.ExecutablePath and Application's Current Default Dir"
bytecodeman
Hi!
I've been using your WinSCP .NET assembly with much success until today where I decided to be adventurous. Smile I wanted to have only one copy of WinSCP stored on my machine. I have multiple applications that references and make use of WINSCP.exe.
All my apps have their own copies of WinSCP.exe in their directories and everything works fine.
I decided to delete all the WinSCP.exe's from the app directories and use the Session.ExecutablePath property to find that one installed executable.
The result is now downloaded files get stored in the Program Files/Winscp directory and not the default directory of the app.
I'm using the latest 5.7.1.
Any ideas?
Much appreciated.
Tony
You are probably not using a full path in target path of the download. It's not recommended.
See http://winscp.net/eng/docs/library_session_getfiles
bytecodeman
I took your suggestion and provided full local paths and things are working great now.
Thx for the reply!
