Topic "login into filzilla server localy"
timbodude
Hi I am having problems loging into my local filezilla server.
I can use FZ ftp clint to log into and access folders.
i need to use WinSCP to automate file downloads which fz doesnt support
in WinSCP I am using ftp no encription
i have the hostname, username, and password correct
the only difference i can see between filezilla ftp client is that i have to use a port number in WINSCP which i dont in FZ ftp. ( i set it to 21 anyway)
the error I get is : The requested name is valid, but no data of the requested type was found.
I looked up the error and it doesn't help me unfortunately.
any help gratefully received. sorry for the newbie question.
Tim
Please attach a complete log file both from WinSCP and FileZilla.
timbodude
Hiya thanks
the log file is as below.
winscp log
. 2015-04-10 11:24:08.460 --------------------------------------------------------------------------
. 2015-04-10 11:24:08.460 WinSCP Version 5.7.1 (Build 5235) (OS 6.1.7601 Service Pack 1 - Windows 7 Enterprise)
. 2015-04-10 11:24:08.460 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2015-04-10 11:24:08.460 Log level: Debug 2, Logging passwords
. 2015-04-10 11:24:08.460 Local account: UOPNET\tjwheeler
. 2015-04-10 11:24:08.460 Working directory: C:\Program Files (x86)\WinSCP
. 2015-04-10 11:24:08.460 Process ID: 5768
. 2015-04-10 11:24:08.460 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2015-04-10 11:24:08.460 Time zone: Current: GMT+1, Standard: GMT+0 (GMT Standard Time), DST: GMT+1 (GMT Daylight Time), DST Start: 29/03/2015, DST End: 25/10/2015
. 2015-04-10 11:24:08.460 Login time: 10 April 2015 11:24:08
. 2015-04-10 11:24:08.460 Session name: tim@[::1] (Site)
. 2015-04-10 11:24:08.460 Host name: [::1] (Port: 21)
. 2015-04-10 11:24:08.460 User name: tim (Password: yes, Key file: No)
. 2015-04-10 11:24:08.460 Transfer Protocol: FTP
. 2015-04-10 11:24:08.460 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2015-04-10 11:24:08.460 Disable Nagle: No
. 2015-04-10 11:24:08.460 Proxy: none
. 2015-04-10 11:24:08.460 Send buffer: 262144
. 2015-04-10 11:24:08.460 UTF: 2
. 2015-04-10 11:24:08.460 FTP: FTPS: None; Passive: Yes [Force IP: A]; MLSD: A [List all: A]
. 2015-04-10 11:24:08.460 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2015-04-10 11:24:08.460 Cache directory changes: Yes, Permanent: Yes
. 2015-04-10 11:24:08.460 Timezone offset: 0h 0m
. 2015-04-10 11:24:08.462 Session upkeep
. 2015-04-10 11:24:08.522 Connecting to [::1] ...
. 2015-04-10 11:24:10.733 The requested name is valid, but no data of the requested type was found.
. 2015-04-10 11:24:10.733 Connection failed.
. 2015-04-10 11:24:10.733 Got reply 1004 to the command 1
* 2015-04-10 11:24:10.775 (EFatal) Connection failed.
* 2015-04-10 11:24:10.775 The requested name is valid, but no data of the requested type was found.
* 2015-04-10 11:24:10.775 Connection failed.
filezilla ftp log
2015-04-10 11:36:33 8000 1 Status: Connecting to [::1]:21...
2015-04-10 11:36:33 8000 1 Status: Connection established, waiting for welcome message...
2015-04-10 11:36:33 8000 1 Response: 220-FileZilla Server version 0.9.50 beta
2015-04-10 11:36:33 8000 1 Response: 220-written by Tim Kosse (tim.kosse@filezilla-project.org)
2015-04-10 11:36:33 8000 1 Response: 220 Please visit https://filezilla-project.org/
2015-04-10 11:36:33 8000 1 Command: AUTH TLS
2015-04-10 11:36:33 8000 1 Response: 502 SSL/TLS authentication not allowed
2015-04-10 11:36:33 8000 1 Command: AUTH SSL
2015-04-10 11:36:33 8000 1 Status: Insecure server, it does not support FTP over TLS.
2015-04-10 11:36:33 8000 1 Command: USER tim
2015-04-10 11:36:33 8000 1 Response: 331 Password required for tim
2015-04-10 11:36:33 8000 1 Command: PASS ***************
2015-04-10 11:36:33 8000 1 Response: 230 Logged on
2015-04-10 11:36:33 8000 1 Command: SYST
2015-04-10 11:36:33 8000 1 Response: 215 UNIX emulated by FileZilla
2015-04-10 11:36:33 8000 1 Command: FEAT
2015-04-10 11:36:33 8000 1 Response: 211-Features:
2015-04-10 11:36:33 8000 1 Response:  MDTM
2015-04-10 11:36:33 8000 1 Response:  REST STREAM
2015-04-10 11:36:33 8000 1 Response:  SIZE
2015-04-10 11:36:33 8000 1 Response:  MLST type*;size*;modify*;
2015-04-10 11:36:33 8000 1 Response:  MLSD
2015-04-10 11:36:33 8000 1 Response:  UTF8
2015-04-10 11:36:33 8000 1 Response:  CLNT
2015-04-10 11:36:33 8000 1 Response:  MFMT
2015-04-10 11:36:33 8000 1 Response:  EPSV
2015-04-10 11:36:33 8000 1 Response:  EPRT
2015-04-10 11:36:33 8000 1 Response: 211 End
2015-04-10 11:36:33 8000 1 Status: Connected
2015-04-10 11:36:33 8000 1 Status: Retrieving directory listing...
2015-04-10 11:36:33 8000 1 Command: PWD
2015-04-10 11:36:33 8000 1 Response: 257 "/" is current directory.
2015-04-10 11:36:33 8000 1 Command: TYPE I
2015-04-10 11:36:33 8000 1 Response: 200 Type set to I
2015-04-10 11:36:33 8000 1 Command: EPSV
2015-04-10 11:36:33 8000 1 Response: 229 Entering Extended Passive Mode (|||50363|)
2015-04-10 11:36:33 8000 1 Command: MLSD
2015-04-10 11:36:33 8000 1 Response: 150 Opening data channel for directory listing of "/"
2015-04-10 11:36:33 8000 1 Response: 226 Successfully transferred "/"
2015-04-10 11:36:33 8000 1 Status: Directory listing of "/" successful
filezilla server log. with successful login from filezilla
(000001) 10/04/2015 11:28:39 - (not logged in) (::1)> Connected on port 21, sending welcome message...
(000001) 10/04/2015 11:28:39 - (not logged in) (::1)> 220-FileZilla Server version 0.9.50 beta
(000001) 10/04/2015 11:28:39 - (not logged in) (::1)> 220-written by Tim Kosse (tim.kosse@filezilla-project.org)
(000001) 10/04/2015 11:28:39 - (not logged in) (::1)> 220 Please visit https://filezilla-project.org/
(000001) 10/04/2015 11:28:39 - (not logged in) (::1)> AUTH TLS
(000001) 10/04/2015 11:28:39 - (not logged in) (::1)> 502 SSL/TLS authentication not allowed
(000001) 10/04/2015 11:28:39 - (not logged in) (::1)> AUTH SSL
(000001) 10/04/2015 11:28:39 - (not logged in) (::1)> USER tim
(000001) 10/04/2015 11:28:39 - (not logged in) (::1)> 331 Password required for tim
(000001) 10/04/2015 11:28:39 - (not logged in) (::1)> PASS ***************
(000001) 10/04/2015 11:28:39 - tim (::1)> 230 Logged on
(000001) 10/04/2015 11:28:39 - tim (::1)> SYST
(000001) 10/04/2015 11:28:39 - tim (::1)> 215 UNIX emulated by FileZilla
(000001) 10/04/2015 11:28:39 - tim (::1)> FEAT
(000001) 10/04/2015 11:28:39 - tim (::1)> 211-Features:
(000001) 10/04/2015 11:28:39 - tim (::1)>  MDTM
(000001) 10/04/2015 11:28:39 - tim (::1)>  REST STREAM
(000001) 10/04/2015 11:28:39 - tim (::1)>  SIZE
(000001) 10/04/2015 11:28:39 - tim (::1)>  MLST type*;size*;modify*;
(000001) 10/04/2015 11:28:39 - tim (::1)>  MLSD
(000001) 10/04/2015 11:28:39 - tim (::1)>  UTF8
(000001) 10/04/2015 11:28:39 - tim (::1)>  CLNT
(000001) 10/04/2015 11:28:39 - tim (::1)>  MFMT
(000001) 10/04/2015 11:28:39 - tim (::1)>  EPSV
(000001) 10/04/2015 11:28:39 - tim (::1)>  EPRT
(000001) 10/04/2015 11:28:39 - tim (::1)> 211 End
(000001) 10/04/2015 11:28:39 - tim (::1)> PWD
(000001) 10/04/2015 11:28:39 - tim (::1)> 257 "/" is current directory.
(000001) 10/04/2015 11:28:39 - tim (::1)> TYPE I
(000001) 10/04/2015 11:28:39 - tim (::1)> 200 Type set to I
(000001) 10/04/2015 11:28:39 - tim (::1)> 229 Entering Extended Passive Mode (|||50021|)
(000001) 10/04/2015 11:28:39 - tim (::1)> 150 Opening data channel for directory listing of "/"
(000001) 10/04/2015 11:28:39 - tim (::1)> 226 Successfully transferred "/"
(000002) 10/04/2015 11:29:35 - (not logged in) (::1)> Connected on port 21, sending welcome message...
(000002) 10/04/2015 11:29:35 - (not logged in) (::1)> 220-FileZilla Server version 0.9.50 beta
(000002) 10/04/2015 11:29:35 - (not logged in) (::1)> 220-written by Tim Kosse (tim.kosse@filezilla-project.org)
(000002) 10/04/2015 11:29:35 - (not logged in) (::1)> 220 Please visit https://filezilla-project.org/
(000002) 10/04/2015 11:29:35 - (not logged in) (::1)> AUTH TLS
(000002) 10/04/2015 11:29:35 - (not logged in) (::1)> 502 SSL/TLS authentication not allowed
(000002) 10/04/2015 11:29:35 - (not logged in) (::1)> AUTH SSL
(000002) 10/04/2015 11:29:35 - (not logged in) (::1)> USER tim
(000002) 10/04/2015 11:29:35 - (not logged in) (::1)> 331 Password required for tim
(000002) 10/04/2015 11:29:35 - (not logged in) (::1)> PASS ***************
(000002) 10/04/2015 11:29:35 - tim (::1)> 230 Logged on
(000002) 10/04/2015 11:29:35 - tim (::1)> PWD
(000002) 10/04/2015 11:29:35 - tim (::1)> 257 "/" is current directory.
(000003) 10/04/2015 11:30:33 - (not logged in) (::1)> Connected on port 21, sending welcome message...
(000003) 10/04/2015 11:30:33 - (not logged in) (::1)> 220-FileZilla Server version 0.9.50 beta
(000003) 10/04/2015 11:30:33 - (not logged in) (::1)> 220-written by Tim Kosse (tim.kosse@filezilla-project.org)
(000003) 10/04/2015 11:30:33 - (not logged in) (::1)> 220 Please visit https://filezilla-project.org/
(000003) 10/04/2015 11:30:33 - (not logged in) (::1)> AUTH TLS
(000003) 10/04/2015 11:30:33 - (not logged in) (::1)> 502 SSL/TLS authentication not allowed
(000003) 10/04/2015 11:30:33 - (not logged in) (::1)> AUTH SSL
(000003) 10/04/2015 11:30:33 - (not logged in) (::1)> USER tim
(000003) 10/04/2015 11:30:33 - (not logged in) (::1)> 331 Password required for tim
(000003) 10/04/2015 11:30:33 - (not logged in) (::1)> PASS ***************
(000003) 10/04/2015 11:30:33 - tim (::1)> 230 Logged on
(000003) 10/04/2015 11:30:33 - tim (::1)> PWD
(000003) 10/04/2015 11:30:33 - tim (::1)> 257 "/" is current directory.
(000003) 10/04/2015 11:30:36 - tim (::1)> disconnected.
(000002) 10/04/2015 11:30:37 - tim (::1)> disconnected.
(000001) 10/04/2015 11:30:40 - tim (::1)> 421 Connection timed out.
(000001) 10/04/2015 11:30:40 - tim (::1)> disconnected.
Thanks for the log.
WinSCP does not allow IPv6 for FTP by default.
Either use IPv4 address (127.0.0.1) or allow IPv6:
http://winscp.net/eng/docs/ui_login_connection
If have modified the default for the next release to allow IPv6:
http://winscp.net/tracker/show_bug.cgi?id=1310
timbodude
Thanks that works great now.
prikryl wrote:
Thanks for the log.
