Topic "Error occurred during logging"
PeteFishwick
I am having problems connecting to an FTP server using .NET
I want to log what is going on when I try to open the connections. I have set the SessionLogPath but when I try the Open I get a SessionRemoteException
of "Error occurred during logging. It's been turned off"
I'd understood that setting SessionLogPath was sufficient to enable logging.
How did you set the SessionLogPath? Did you include a filename in the path?
PeteFishwick
No, I just set it as:
Dim SessionLogpPath As String = "C:\"
Should I have included a filename?
Sure. It's a path to the log. Not a path to a log directory.
PeteFishwick
Thank you
