Topic "Can't get attributes of file error during FTP download"
I have a powershell script that I am useing and I cannot download a file. I recieve the error "Can't get attributes of file..." and inside my log file it says:
      <message>Can't get attributes of file '/ /download/100_MBytes.txt'.</message>
      <message>Could not retrieve file information</message>
      <message>SIZE: Not owner</message
But I am able to download the file using the GUI. What could cause this? I am using the path "/download/<filename>" but when I go into the GUI the root folder is just "/", could this be the cause of it? My other servers have the path "/home/...". I have attached my powershell script and my log file. Note: I have removed all of the login information due to it being confidential.
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
# Session.FileTransferProgress event handler
function FileTransferProgress
    param($e)
    # New line for every new file
    if (($script:lastFileName -ne $Null) -and
        ($script:lastFileName -ne $e.FileName))
        Write-Host
    # Print transfer progress
    Write-Host -NoNewline ("`r{0} ({1:P0})" -f $e.FileName, $e.FileProgress)
    # Remember a name of the last file reported
    $script:lastFileName = $e.FileName
# Main script
$script:lastFileName = $Null
try
   Write-Host "Please wait while startup procedures run"
    $sessionOptions.Protocol = [WinSCP.Protocol]::ftp
   $sessionOptions.HostName = "xxx"
    $sessionOptions.UserName = "xxxx"
    $sessionOptions.Password = "xxxx"
   $sessionOptions.FtpMode = [WinSCP.FtpMode]::passive
   $sessionOptions.AddRawSettings("SendBuf","4096");
   #$sessionOptions.AddRawSettings("Compression","1");
   #$sessionOptions.AddRawSettings("Cipher","blowfish,aes,3des,WARN,arcfour,des");
   #$sessionOptions.AddRawSettings("Cipher","blowfish");
    #$sessionOptions.SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
    try
        # Will continuously report progress of transfer
        $session.add_FileTransferProgress( { FileTransferProgress($_) } )
        # Connect
      $session.DebugLogPath = "WinSCP.log"
      $remotePath = "/download/100_MBytes.txt"
        $localPath = "C:\download\100_MBytes.txt"
      # Force binary transfer
        $transferOptions.TransferMode = [WinSCP.TransferMode]::Ascii
      Write-Host "Starting download"
        $start = Get-Date  # Get start time
      #$directory = $session.ListDirectory("/download")
        #foreach ($fileInfo in $directory.Files)
        #    Write-Host ("{0} with size {1}, permissions {2} and last modification at {3}" -f
         #       $fileInfo.Name, $fileInfo.Length, $fileInfo.FilePermissions, $fileInfo.LastWriteTime)
        # Download the file and throw on any error
      $session.GetFiles($remotePath, $localPath).Check()
      # Get end time and calculate throughput
      $duration = (Get-Date) - $start
        $size = (Get-Item $localPath).Length
      $sizeInKb = (Get-Item $localPath).Length / 1024
        $speed = $sizeInKb / $duration.TotalSeconds
      Write-Host
      Write-Host ("Downloaded file {0} to {1}" -f $remotePath, $localPath)
        Write-Host ("Size {0:N0} B | Time {1:hh\:mm\:ss}" -f $size, $duration)
        Write-Host ("Speed {0:N0} KB/s" -f $speed)
    finally
        # Terminate line after the last file (if any)
        if ($script:lastFileName -ne $Null)
            Write-Host
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host $_.Exception.Message
    exit 1
WinSCP.log (16.61 KB) [Download]
Description: (none)
ducksauce88
Not sure why it was showing as a "guest" but I am the one who submitted this.
mrsmalltalk
hi,
i'm having a similar problem. i'm downloading 2 files from ES File Explorer running on Android 5.0.2 to winscp 5.7.6 (5874) on win7. i'm downloading 2 files from the same directory. i'm using with bat files. one consistently works and the other fails. i have attached the 2 .bat files and the 2 winscp logs. the files both exist on the android and i don't think i have any typos. if necessary i can send the actual files. they are small.
john
FTPFailLogs.txt (107.91 KB) [Download]
Description: i put all logs and batch files here
There's no 20160120DataFromAndroid.txt in the /66DATA99/Input/BocceLog/ directory.
Quote:
-rw-r--r-- 1 nobody nobody 1172 Jan 20 10:22 DataToAndroid.txt
-rw-r--r-- 1 nobody nobody 31 Jan 20 15:08 CurrentFilename.txt
-rw-r--r-- 1 nobody nobody 960 Jan 11 15:55 20160111DataToSmalltalk.txt
-rw-r--r-- 1 nobody nobody 472 Jan 14 12:24 20160113DataToSmalltalk.txt
-rw-r--r-- 1 nobody nobody 412 Jan 08 15:42 20160108DataToSmalltalk.txt
-rw-r--r-- 1 nobody nobody 903 Jan 18 15:18 20160118DataToSmalltalk.txt
-rw-r--r-- 1 nobody nobody 875 Jan 20 15:08 20160120DataToSmalltalk.txt
mrsmalltalk
my mistake.
i'm generating batch files on the fly. to test i cut and pasted from another batch file which obviously had the wrong file name but correct date, so the asterisk worked based on a date hit.
again, my apologies.
john
