Topic "WinSCP 5.7.1 - SFTP 6 no longer working"
biffer
Hi Martin,
since I upgraded WinSCP to Version 5.7.1, I keep getting the follwing error messages after login when using SFTP version 6:
Cannot get real path for '/'.
Bad message (badly formatted packet or protocol incompatibility).
Error code: 5
Error message from server (en): badly encoded SFTP packet
Error getting name of current remote directory.
Cannot get real path for '.'.
Error code: 5
Error listing directory ''.
No such file or directory.
Error code: 2
Error message from server (en): No such file or directory
SFTP versions 5 and below as well as WinSCP up to version 5.7.0 are working fine. I presume it has to do with the changes implemented for bug 1289.
I attached two full log files, one for version 5.7.0 and one for 5.7.1.
Thanks for your help.
winscp571.log (43.2 KB) [Download]
Description: (none)
winscp570.log (34.13 KB) [Download]
Description: (none)
http://winscp.net/tracker/show_bug.cgi?id=1308
I'm sending you an email with a development version of WinSCP to address you have used to register on this forum.
biffer
I just tried the latest nightly build and the problem seems to be fixed now. Thanks for the quick resolution!
Thanks for your feedback.
