Topic "[5.7.1][FTP]Error "Real path and requested remote..""
teledug
FTP protocol
I receive error, when usign winscp.com:
Connecting to server ...
Connected
Starting the session...
Session started.
Active session: [1] test@server
transfer        binary
Comparing...
Local 'C:\Users\user\Desktop\tmp\1E\7zEAAD0\bin' <= Remote '/home/7zEAAD0/bin'
Synchronizing...
Local 'C:\Users\user\Desktop\tmp\1E\7zEAAD0' <= Remote '/home/7zEAAD0'
etc                       |            0 B |    0,0 KB/s | binary |   0%
file.conf                 |            0 B |    0,0 KB/s | binary |   0%
Error transferring file '/home/7zEAAD0/etc/file.conf'.
Real path and requested remote path do not match: "/homes/test/7zEAAD0/etc/
"  "/home/7zEAAD0/etc/"
Copying files from remote side failed.
And when I use gui version - everything works fine. What is the problem?
teledug
script file:
open   ftp://test:123456@server
option transfer binary
synchronize local C:\Users\user\Desktop\tmp\1E "/home"
[/code]
teledug
. 2015-04-08 14:45:54.686 --------------------------------------------------------------------------
. 2015-04-08 14:45:54.686 WinSCP Version 5.7.1 (Build 5235) (OS 5.2.3790 Service Pack 2 - Microsoft Windows Server 2003)
. 2015-04-08 14:45:54.686 Configuration: C:\Program Files\IBM\Domino\data\ftpworkdir\Winscp.ini
. 2015-04-08 14:45:54.686 Log level: Debug 1
. 2015-04-08 14:45:54.686 Local account: mypc\user
. 2015-04-08 14:45:54.686 Working directory: C:\Program Files\IBM\Domino\data\ftpworkdir
. 2015-04-08 14:45:54.686 Process ID: 8724
. 2015-04-08 14:45:54.686 Command-line: "C:\Program Files\IBM\Domino\data\ftpworkdir\Winscp.exe" /console=571 /consoleinstance=_1772_472 "/script=C:\ftptempdir\1E.conf" "/log=C:\ftptempdir\1E.transferlog" "/loglevel=1"
. 2015-04-08 14:45:54.686 Switch:    /console=571
. 2015-04-08 14:45:54.686 Switch:    /consoleinstance=_1772_472
. 2015-04-08 14:45:54.686 Switch:    /script=C:\ftptempdir\1E.conf
. 2015-04-08 14:45:54.686 Switch:    /log=C:\ftptempdir\1E.transferlog
. 2015-04-08 14:45:54.686 Switch:    /loglevel=1
. 2015-04-08 14:45:54.686 Time zone: Current: GMT+4 (Russian Standard Time), No DST
. 2015-04-08 14:45:54.686 Login time: 8 Апрель 2015 г. 14:45:54
. 2015-04-08 14:45:54.686 Script: Retrospectively logging previous script records:
> 2015-04-08 14:45:54.686 Script: open ftp://test:***@[SERVER]
> 2015-04-08 14:45:54.686 Script: Parameter: ftp://test:***@[SERVER]
. 2015-04-08 14:45:54.686 Session name: test@[SERVER] (Ad-Hoc site)
. 2015-04-08 14:45:54.686 Host name: [SERVER] (Port: 21)
. 2015-04-08 14:45:54.686 User name: test (Password: Yes, Key file: No)
. 2015-04-08 14:45:54.686 Transfer Protocol: FTP
. 2015-04-08 14:45:54.686 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2015-04-08 14:45:54.686 Disable Nagle: No
. 2015-04-08 14:45:54.686 Proxy: none
. 2015-04-08 14:45:54.686 Send buffer: 262144
. 2015-04-08 14:45:54.686 UTF: 2
. 2015-04-08 14:45:54.686 FTP: FTPS: None; Passive: Yes [Force IP: A]; MLSD: A [List all: A]
. 2015-04-08 14:45:54.686 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2015-04-08 14:45:54.686 Cache directory changes: Yes, Permanent: Yes
. 2015-04-08 14:45:54.686 Timezone offset: 0h 0m
. 2015-04-08 14:45:54.696 Connecting to [SERVER] ...
. 2015-04-08 14:45:54.696 Connected with [SERVER]. Waiting for welcome message...
< 2015-04-08 14:45:54.706 220 NASFTPD Turbo station 1.3.2e Server (ProFTPD) [[SERVER]]
> 2015-04-08 14:45:54.706 USER test
< 2015-04-08 14:45:54.736 331 Password required for test
> 2015-04-08 14:45:54.736 PASS ******
< 2015-04-08 14:45:56.979 230 User test logged in
> 2015-04-08 14:45:56.979 SYST
< 2015-04-08 14:45:56.979 215 UNIX Type: L8
> 2015-04-08 14:45:56.979 FEAT
< 2015-04-08 14:45:56.989 211-Features:
< 2015-04-08 14:45:56.989  MDTM
< 2015-04-08 14:45:56.989  MFMT
< 2015-04-08 14:45:56.989  MFF modify;UNIX.group;UNIX.mode;
< 2015-04-08 14:45:56.989  MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
< 2015-04-08 14:45:56.989  LANG en-US*
< 2015-04-08 14:45:56.989  REST STREAM
< 2015-04-08 14:45:56.989  SIZE
< 2015-04-08 14:45:56.989 211 End
. 2015-04-08 14:45:56.989 Connected
. 2015-04-08 14:45:56.989 Got reply 1 to the command 1
. 2015-04-08 14:45:56.989 --------------------------------------------------------------------------
. 2015-04-08 14:45:56.989 Using FTP protocol.
. 2015-04-08 14:45:56.989 Doing startup conversation with host.
> 2015-04-08 14:45:56.989 PWD
< 2015-04-08 14:45:56.989 257 "/" is the current directory
. 2015-04-08 14:45:56.989 Got reply 1 to the command 16
. 2015-04-08 14:45:56.989 Getting current directory name.
. 2015-04-08 14:45:56.989 Startup conversation with host finished.
< 2015-04-08 14:45:56.989 Script: Active session: [1] test@[SERVER]
. 2015-04-08 14:45:56.989 Session upkeep
> 2015-04-08 14:45:56.989 Script: option transfer binary
> 2015-04-08 14:45:56.989 Script: Parameter: transfer
> 2015-04-08 14:45:56.989 Script: Parameter: binary
< 2015-04-08 14:45:56.989 Script: transfer        binary
. 2015-04-08 14:45:56.999 Session upkeep
> 2015-04-08 14:45:56.999 Script: synchronize local C:\ftptempdir\1E "/home"
> 2015-04-08 14:45:56.999 Script: Parameter: local
> 2015-04-08 14:45:56.999 Script: Parameter: C:\ftptempdir\1E
> 2015-04-08 14:45:56.999 Script: Parameter: /home
< 2015-04-08 14:45:56.999 Script: Comparing...
. 2015-04-08 14:45:56.999 Collecting synchronization list for local directory 'C:\ftptempdir\1E' and remote directory '/home', mode = Local, params = 0x2 (NoConfirmation)
. 2015-04-08 14:45:56.999 Local file 'C:\ftptempdir\1E\.' [2015-04-08T10:45:54.356Z] [0] excluded from synchronization
. 2015-04-08 14:45:56.999 Local file 'C:\ftptempdir\1E\..' [2015-04-08T10:45:54.356Z] [0] excluded from synchronization
. 2015-04-08 14:45:56.999 Retrieving directory listing...
> 2015-04-08 14:45:56.999 CWD /home/
< 2015-04-08 14:45:56.999 250 CWD command successful
> 2015-04-08 14:45:56.999 PWD
< 2015-04-08 14:45:57.009 257 "/homes/test" is the current directory
> 2015-04-08 14:45:57.009 TYPE A
< 2015-04-08 14:45:57.009 200 Type set to A
> 2015-04-08 14:45:57.009 PASV
< 2015-04-08 14:45:57.009 227 Entering Passive Mode ([SERVER],188).
> 2015-04-08 14:45:57.009 MLSD
. 2015-04-08 14:45:57.009 Connecting to [SERVER]:56508 ...
< 2015-04-08 14:45:57.029 150 Opening ASCII mode data connection for MLSD
. 2015-04-08 14:45:57.039 modify=20150407161241;perm=flcdmpe;type=dir;unique=900U136005F4;UNIX.group=100;UNIX.mode=0777;UNIX.owner=519; 7zEAAD0
. 2015-04-08 14:45:57.039 modify=20150408105946;perm=flcdmpe;type=dir;unique=900U136005F3;UNIX.group=100;UNIX.mode=0711;UNIX.owner=519; .
< 2015-04-08 14:45:57.039 226 Transfer complete
. 2015-04-08 14:45:57.039 Directory listing successful
. 2015-04-08 14:45:57.039 Got reply 1 to the command 2
. 2015-04-08 14:45:57.039 ..;D;0;1899-12-30T04:00:00.000Z;"" [0];"" [0];---------;0
. 2015-04-08 14:45:57.039 7zEAAD0;D;0;2015-04-07T16:12:41.000Z;"519" [0];"100" [0];rwxrwxrwx;1
. 2015-04-08 14:45:57.059 Remote file '/home/7zEAAD0' [2015-04-07T16:12:41.000Z] [0] is new
< 2015-04-08 14:45:57.059 Script: Synchronizing...
. 2015-04-08 14:45:57.059 Synchronizing local directory 'C:\ftptempdir\1E\' with remote directory '/home/', params = 0x2 (NoConfirmation)
. 2015-04-08 14:45:57.059 Copying 1 files/directories to local directory "C:\ftptempdir\1E\"
. 2015-04-08 14:45:57.059   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask: *.*
. 2015-04-08 14:45:57.059   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: ; ResumeL: 0
. 2015-04-08 14:45:57.059   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2015-04-08 14:45:57.059 File: '/home/7zEAAD0' [2015-04-07T16:12:41.000Z] [0]
< 2015-04-08 14:45:57.059 Script: Local 'C:\ftptempdir\1E' <= Remote '/home'
. 2015-04-08 14:45:57.059 Retrieving directory listing...
> 2015-04-08 14:45:57.059 CWD /home/7zEAAD0/
< 2015-04-08 14:45:57.069 250 CWD command successful
> 2015-04-08 14:45:57.069 PWD
< 2015-04-08 14:45:57.079 257 "/homes/test/7zEAAD0" is the current directory
> 2015-04-08 14:45:57.079 TYPE A
< 2015-04-08 14:45:57.079 200 Type set to A
> 2015-04-08 14:45:57.079 PASV
< 2015-04-08 14:45:57.079 227 Entering Passive Mode ([SERVER],7).
> 2015-04-08 14:45:57.079 MLSD
. 2015-04-08 14:45:57.079 Connecting to [SERVER]:56327 ...
< 2015-04-08 14:45:57.089 150 Opening ASCII mode data connection for MLSD
. 2015-04-08 14:45:57.089 modify=20150407161241;perm=flcdmpe;type=dir;unique=900U136005F7;UNIX.group=100;UNIX.mode=0777;UNIX.owner=519; tmp
. 2015-04-08 14:45:57.089 modify=20150407161248;perm=flcdmpe;type=dir;unique=900U136005F5;UNIX.group=100;UNIX.mode=0777;UNIX.owner=519; bin
. 2015-04-08 14:45:57.089 modify=20150407161248;perm=flcdmpe;type=dir;unique=900U136005F6;UNIX.group=100;UNIX.mode=0777;UNIX.owner=519; etc
. 2015-04-08 14:45:57.089 modify=20150408105946;perm=flcdmpe;type=dir;unique=900U136005F3;UNIX.group=100;UNIX.mode=0711;UNIX.owner=519; ..
. 2015-04-08 14:45:57.089 modify=20150407161241;perm=flcdmpe;type=dir;unique=900U136005F4;UNIX.group=100;UNIX.mode=0777;UNIX.owner=519; .
< 2015-04-08 14:45:57.089 226 Transfer complete
. 2015-04-08 14:45:57.089 Directory listing successful
. 2015-04-08 14:45:57.089 Got reply 1 to the command 2
. 2015-04-08 14:45:57.089 ..;D;0;1899-12-30T04:00:00.000Z;"" [0];"" [0];---------;0
. 2015-04-08 14:45:57.089 tmp;D;0;2015-04-07T16:12:41.000Z;"519" [0];"100" [0];rwxrwxrwx;1
. 2015-04-08 14:45:57.089 bin;D;0;2015-04-07T16:12:48.000Z;"519" [0];"100" [0];rwxrwxrwx;1
. 2015-04-08 14:45:57.089 etc;D;0;2015-04-07T16:12:48.000Z;"519" [0];"100" [0];rwxrwxrwx;1
. 2015-04-08 14:45:57.089 File: '/home/7zEAAD0/tmp' [2015-04-07T16:12:41.000Z] [0]
. 2015-04-08 14:45:57.099 Retrieving directory listing...
> 2015-04-08 14:45:57.099 CWD /home/7zEAAD0/tmp/
< 2015-04-08 14:45:57.099 250 CWD command successful
> 2015-04-08 14:45:57.099 PWD
< 2015-04-08 14:45:57.109 257 "/homes/test/7zEAAD0/tmp" is the current directory
> 2015-04-08 14:45:57.109 TYPE A
< 2015-04-08 14:45:57.109 200 Type set to A
> 2015-04-08 14:45:57.109 PASV
< 2015-04-08 14:45:57.119 227 Entering Passive Mode ([SERVER],135).
> 2015-04-08 14:45:57.119 MLSD
. 2015-04-08 14:45:57.119 Connecting to [SERVER]:56455 ...
< 2015-04-08 14:45:57.140 150 Opening ASCII mode data connection for MLSD
. 2015-04-08 14:45:57.150 modify=20150407161241;perm=flcdmpe;type=dir;unique=900U136005F4;UNIX.group=100;UNIX.mode=0777;UNIX.owner=519; ..
. 2015-04-08 14:45:57.150 modify=20150407161241;perm=flcdmpe;type=dir;unique=900U136005F7;UNIX.group=100;UNIX.mode=0777;UNIX.owner=519; .
< 2015-04-08 14:45:57.150 226 Transfer complete
. 2015-04-08 14:45:57.150 Directory listing successful
. 2015-04-08 14:45:57.150 Got reply 1 to the command 2
. 2015-04-08 14:45:57.150 ..;D;0;1899-12-30T04:00:00.000Z;"" [0];"" [0];---------;0
. 2015-04-08 14:45:57.150 File: '/home/7zEAAD0/bin' [2015-04-07T16:12:48.000Z] [0]
. 2015-04-08 14:45:57.150 Retrieving directory listing...
> 2015-04-08 14:45:57.150 CWD /home/7zEAAD0/bin/
< 2015-04-08 14:45:57.160 250 CWD command successful
> 2015-04-08 14:45:57.160 PWD
< 2015-04-08 14:45:57.170 257 "/homes/test/7zEAAD0/bin" is the current directory
> 2015-04-08 14:45:57.170 TYPE A
< 2015-04-08 14:45:57.170 200 Type set to A
> 2015-04-08 14:45:57.170 PASV
< 2015-04-08 14:45:57.170 227 Entering Passive Mode ([SERVER],163).
> 2015-04-08 14:45:57.170 MLSD
. 2015-04-08 14:45:57.170 Connecting to [SERVER]:55715 ...
< 2015-04-08 14:45:57.190 150 Opening ASCII mode data connection for MLSD
. 2015-04-08 14:45:57.190 modify=20150407161244;perm=adfrw;size=1021971;type=file;unique=900U136005FC;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; cygiconv-2.dll
. 2015-04-08 14:45:57.190 modify=20150407161247;perm=adfrw;size=80915;type=file;unique=900U13600603;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; cygz.dll
. 2015-04-08 14:45:57.190 modify=20150407161241;perm=flcdmpe;type=dir;unique=900U136005F4;UNIX.group=100;UNIX.mode=0777;UNIX.owner=519; ..
. 2015-04-08 14:45:57.190 modify=20150407161248;perm=adfrw;size=1079808;type=file;unique=900U13600604;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; lftp.exe
. 2015-04-08 14:45:57.190 modify=20150407161244;perm=adfrw;size=38931;type=file;unique=900U136005FD;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; cygintl-8.dll
. 2015-04-08 14:45:57.190 modify=20150407161245;perm=adfrw;size=10771;type=file;unique=900U13600601;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; cygssp-0.dll
. 2015-04-08 14:45:57.190 modify=20150407161245;perm=adfrw;size=386048;type=file;unique=900U13600600;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; cygssl-1.0.0.dll
. 2015-04-08 14:45:57.190 modify=20150407161245;perm=adfrw;size=197139;type=file;unique=900U136005FF;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; cygreadline7.dll
. 2015-04-08 14:45:57.190 modify=20150407161243;perm=adfrw;size=1694720;type=file;unique=900U136005F9;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; cygcrypto-1.0.0.dll
. 2015-04-08 14:45:57.190 modify=20150407161248;perm=flcdmpe;type=dir;unique=900U136005F5;UNIX.group=100;UNIX.mode=0777;UNIX.owner=519; .
. 2015-04-08 14:45:57.190 modify=20150407161242;perm=adfrw;size=632851;type=file;unique=900U136005F8;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; bash.exe
. 2015-04-08 14:45:57.190 modify=20150407161243;perm=adfrw;size=68115;type=file;unique=900U136005FB;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; cyggcc_s-seh-1.dll
. 2015-04-08 14:45:57.190 modify=20150407161243;perm=adfrw;size=150035;type=file;unique=900U136005FA;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; cygexpat-1.dll
. 2015-04-08 14:45:57.190 modify=20150407161248;perm=adfrw;size=388115;type=file;unique=900U13600605;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; ssh.exe
. 2015-04-08 14:45:57.190 modify=20150407161244;perm=adfrw;size=301587;type=file;unique=900U136005FE;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; cygncursesw-10.dll
. 2015-04-08 14:45:57.190 modify=20150407161247;perm=adfrw;size=3145043;type=file;unique=900U13600602;UNIX.group=100;UNIX.mode=0666;UNIX.owner=519; cygwin1.dll
< 2015-04-08 14:45:57.190 226 Transfer complete
. 2015-04-08 14:45:57.190 Directory listing successful
. 2015-04-08 14:45:57.190 Got reply 1 to the command 2
. 2015-04-08 14:45:57.190 ..;D;0;1899-12-30T04:00:00.000Z;"" [0];"" [0];---------;0
. 2015-04-08 14:45:57.190 cygiconv-2.dll;-;1021971;2015-04-07T16:12:44.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 cygz.dll;-;80915;2015-04-07T16:12:47.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 lftp.exe;-;1079808;2015-04-07T16:12:48.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 cygintl-8.dll;-;38931;2015-04-07T16:12:44.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 cygssp-0.dll;-;10771;2015-04-07T16:12:45.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 cygssl-1.0.0.dll;-;386048;2015-04-07T16:12:45.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 cygreadline7.dll;-;197139;2015-04-07T16:12:45.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 cygcrypto-1.0.0.dll;-;1694720;2015-04-07T16:12:43.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 bash.exe;-;632851;2015-04-07T16:12:42.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 cyggcc_s-seh-1.dll;-;68115;2015-04-07T16:12:43.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 cygexpat-1.dll;-;150035;2015-04-07T16:12:43.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 ssh.exe;-;388115;2015-04-07T16:12:48.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 cygncursesw-10.dll;-;301587;2015-04-07T16:12:44.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 cygwin1.dll;-;3145043;2015-04-07T16:12:47.000Z;"519" [0];"100" [0];rw-rw-rw-;1
. 2015-04-08 14:45:57.190 File: '/home/7zEAAD0/bin/cygiconv-2.dll' [2015-04-07T16:12:44.000Z] [1021971]
. 2015-04-08 14:45:57.190 Copying "/home/7zEAAD0/bin/cygiconv-2.dll" to local directory started.
. 2015-04-08 14:45:57.190 Binary transfer mode selected.
. 2015-04-08 14:45:57.190 Starting download of /home/7zEAAD0/bin/cygiconv-2.dll
> 2015-04-08 14:45:57.190 CWD /home/7zEAAD0/bin/
< 2015-04-08 14:45:57.200 250 CWD command successful
> 2015-04-08 14:45:57.200 PWD
< 2015-04-08 14:45:57.200 257 "/homes/test/7zEAAD0/bin" is the current directory
. 2015-04-08 14:45:57.200 Real path and requested remote path do not match: "/homes/test/7zEAAD0/bin/"  "/home/7zEAAD0/bin/"
. 2015-04-08 14:45:57.200 Copying files from remote side failed.
. 2015-04-08 14:45:57.200 Got reply 2004 to the command 4
* 2015-04-08 14:45:57.200 (ExtException) **Real path and requested remote path do not match: "/homes/test/7zEAAD0/bin/"  "/home/7zEAAD0/bin/"**
* 2015-04-08 14:45:57.200 Copying files from remote side failed.
. 2015-04-08 14:45:57.200 Asking user:
. 2015-04-08 14:45:57.200 Error transferring file '/home/7zEAAD0/bin/cygiconv-2.dll'. ("Real path and requested remote path do not match: ""/homes/test/7zEAAD0/bin/""  ""/home/7zEAAD0/bin/""","Copying files from remote side failed.")
< 2015-04-08 14:45:57.200 Script: Error transferring file '/home/7zEAAD0/bin/cygiconv-2.dll'.
< 2015-04-08 14:45:57.200 Script: Real path and requested remote path do not match: "/homes/test/7zEAAD0/bin/"  "/home/7zEAAD0/bin/"
< 2015-04-08 14:45:57.200 Copying files from remote side failed.
* 2015-04-08 14:45:57.210 (EScpSkipFile) Error transferring file '/home/7zEAAD0/bin/cygiconv-2.dll'.
* 2015-04-08 14:45:57.210 Real path and requested remote path do not match: "/homes/test/7zEAAD0/bin/"  "/home/7zEAAD0/bin/"
* 2015-04-08 14:45:57.210 Copying files from remote side failed.
. 2015-04-08 14:45:57.210 Script: Failed
. 2015-04-08 14:45:57.210 Session upkeep
. 2015-04-08 14:45:57.210 Script: Exit code: 1
. 2015-04-08 14:45:57.210 Got reply 1004 to the command 4
. 2015-04-08 14:45:57.210 Disconnected from server
There's some symlink in the path. I'd say that in GUI you actually synchronize a the symlink points too.
If this does not help, please attach a full log file from GUI (using the latest version of WinSCP).
teledug
Hello! Thank you for the answer. I have checked in GUI version, it changes path automatically:
I see in explorer /home, when I enter this dir I have /homes/test, but not /home. When I try to synchronize /home - I receive same error "Real path and requested remote path do not match" , like in a .com version.
Anyway, GUI version can synchronize directory correctly, but .com version gives me an error. Should I still post log from GUI?
"Resolve Symbolic links" is active in GUI by default and cannot be changed.
How can I make .com version behave like GUI version?
So just use /homes/test in the script.
teledug
Sadly, but this is unacceptalbe. I use winscp.com version in script and as parameter it can receive root of ftp server. When it tries to sync I receive same error:
Real path and requested remote path do not match: "/homes/test/7zEAAD0/etc/" "/home/7zEAAD0/etc/"
Is there any way for the winscp.com to behave like GUI version? It can detect path in automatic way, but winscp.com - cannot.
I do not understand when do you get this error. Is this still the same scenario as before? Or does this happen when you use /homes/test in synchronize command?
teledug
winscp.exe /console with same script gives me same result.
I'll try to clarify my problem.
When I try to list root of ftp server, I receive following:
/home
/Multimedia
/Public
When I do:
synchronize local C:\testdir "/home"
I get error.
I do not know about /homes/tester
When I enter /home directory in GUI version I see /homes/tester path, not /home
When I enter /home directory in Windows Explorer I see ftp://myserver/home/
I'm not sure, if that behavior is correct for winscp.com
In windows explorer
teledug
My steps:
1. Login ftp server and receive listing
2. Select required directory from listing (Let it be /home )
3. Make script:
synchronize local "C:\test" "/home"
4. start winscp.com with this script.
So I receive this error when I try to sync directory which I see from listing.
OK, I do not understand why you cannot use /homes/test with the synchronize command.
If you need to use the /home path explicitly, try this:
cd "/home"
synchronize local "C:\test" "."
This is what the GUI does.
teledug
cd "/home"
Awesome! This works like a charm! Thank you!
I'm unable to use /homes/test because I dont see it when I make "ls /"
