Topic "Can't get attributes of file '/'."
codenat
I have written a windows service that periodically checks the ftp for new files. When it finds a file, it ftp's the file to another server. The first time it found a file, I received this error:
Message: Can't get attributes of file '/'.
Stack Trace: at WinSCP.OperationResultBase.Check()
I am attaching a log of the event.
Here is the method that I am using:
        private void qtsTimer_Elapsed(object sender, ElapsedEventArgs e)
            string localPath = @"U:\CLM";
            string remotePath = "/";
            MyProgram_eventLog.WriteEntry("Checking the " + remotePath + " with the qtsTimer: " + DateTime.Now.ToString(), EventLogEntryType.Information);
            FtpQTS(localPath, remotePath);
        private void FtpQTS(string localPath, string remotePath)
            ///<summary>The full path of the file on the FTP server.</summary>
            string remoteFile;
            try
                // Setup session options
                    Protocol = Protocol.Ftp,
                    HostName = "ftp.comany.com",
                    UserName = "ftpuser",
                    Password = "ftppass",
                    // If using Protocol.Sftp then you would add the following line
                    // SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
                MyProgram_eventLog.WriteEntry("A connection to ftpuser on ftpserver has been made", EventLogEntryType.Information);
                    //log session
                    session.SessionLogPath = @"U:\CLM\Logs\WinSCPLog.log";
                    // Connect
                    session.Open(sessionOptions);
                    RemoteDirectoryInfo remoteDirectory = session.ListDirectory(remotePath);
                    MyProgram_eventLog.WriteEntry("Checking " + remotePath + " on ftpuser ftpserver for new files", EventLogEntryType.Information);
                    foreach (RemoteFileInfo fileInfo in remoteDirectory.Files)
                        if (fileInfo.Name != "..")
                            remoteFile = remotePath + fileInfo.Name;
                            MyProgram_eventLog.WriteEntry("A new file has been found: " + fileInfo.Name, EventLogEntryType.Information);
                            // Download the file and throw on any error
                            session.GetFiles(remotePath, localPath).Check();
                            MyProgram_eventLog.WriteEntry("Download to " + localPath + " done", EventLogEntryType.Information);
                            // Remove the file
                            session.RemoveFiles(remoteFile);
                            MyProgram_eventLog.WriteEntry("Removed file: " + remoteFile, EventLogEntryType.Information);
                        else
                            MyProgram_eventLog.WriteEntry("Found " + fileInfo.Name + " which is not a new file", EventLogEntryType.Information);
            catch (Exception ex)
                MyProgram_eventLog.WriteEntry("There was a problem in FtpQTS(): " + ex.ToString(), EventLogEntryType.Error);
                EmailError(ref ex);
Thanks for your help.
WinSCPLog150407_118.log (6.02 KB) [Download]
Description: WinSCP Session Log
There's no "Can't get attributes of file '/'." error in the log. Are you sure you have attached a correct log file? What it is a full call stack of the exception? Do you know what line of a code throws the exception?
codenat
Sorry ... I must've gotten my logs confused. Attached is the log with the error.
Full error:
Stack Trace:
at WinSCP.OperationResultBase.Check() at FTP_Check4Files.FTP_Check4Files.FtpQTS(String localPath, String remotePath)
WinSCPLog150407_1318.log (7.14 KB) [Download]
Description: (none)
It looks like a bug in the FTP server.
When WinSCP asks it for a details on the root folder (/), it responds with information on ftpuser folder.
It's likely because the FTP root is physically a path like /home/ftpuser.
But the FTP server should completely isolate the client from that, let only that this is a security flaw.
Do you know what FTP server software is that? So that I can report this to the vendor.
Anyway, you might be able to workaround this using:
SessionOptions.AddRawSettings("FtpUseMlsd", "1");
This sets Use MLSD command for directory listing option to Off.
http://winscp.net/eng/docs/ui_login_ftp
codenat
Thanks for your quick response! IPSwitch File Transfer WS_FTP Server is what it uses.
As of 15.04.16, it ran again with the addition of the above line of code. Received a similar error once again and the file did not get transferred. I am attaching the log of today's try. Here is the error:
error wrote:
There was a problem in FtpQTS(): WinSCP.SessionRemoteException: Can't get attributes of file '/'. ---> WinSCP.SessionRemoteException: Could not retrieve file information Invalid number of arguments SIZE --- End of inner exception stack trace --- at WinSCP.OperationResultBase.Check() at FTP_Check4Files.FTP_Check4Files.FtpQTS(String localPath, String remotePath)
150416Log.log (7.77 KB) [Download]
Description: Log with error from today's run after adding the recommended
Thanks.
Actually my previous analysis was wrong.
It's a bug in WinSCP:
http://winscp.net/tracker/show_bug.cgi?id=1314
I'm sending you an email with a development version of WinSCP to address you have used to register on this forum.
codenat
Well, unfortunately, the new .dll and .exe didn't seem to work.
Attached is the log file.
150428_1205Log.log (7.2 KB) [Download]
Description: 12:05 attempt at FTPing a file.
Thanks. I'm sending you an email with a new development version.
