Topic "Error 2146233321 Automation error"
eddy.peng
I created a VB6 application to transfer files via SFTP.
I downloaded WinSCP.exe, WinSCPnet.dll and use the following to register the dll for COM type library:
C:\Windows\Microsoft.NET\Framework\v4.0.30319\regasm.exe WinSCPnet.dll /codebase /tlb
In my VB6 application, I add a reference to WinSCPnet.tlb, the VB6 application works fine in test environment(Windows Server 2003), but I got -2146233321 Automation error when I deploy into Production environment(Windows Server 2003), this error occurs when trying to create SessionOptions object as shown below:
Private Sub cmdCreateSession_Click()
On Error GoTo Err_Handler
Dim mySessionOptions As New SessionOptions
' Setup session options
With mySessionOptions
.Protocol = Protocol.Protocol_Sftp
.HostName = txtRemoteHost
.UserName = txtUserName
.Password = txtPassword
.SshHostKeyFingerprint = txtFingerPrint
End With
' Connect
Set gSession = New Session
gSession.Open mySessionOptions
MsgBox "Session is created successfully"
Exit Sub
Err_Handler:
MsgBox Err.Number & ":" & Err.Description
Exit Sub
End Sub
But it works fine when I run debug in production environment, I only get this error when I run .exe from Production environment.
Does anyone have any idea about this error?
Are you running the .exe using the same local account?
eddy.peng
Yes, I'm using the same local account to run .exe and to debug.
I also tried to take the image of production machine and restore it into test network, the .exe works fine, when we restored the image back to production network, I got the same error when it tries to create SessionOptions object.
It really puzzles me and it's just not working in production network.
Your help is highly appreciated.
Try to inspect assembly loading with Assembly Binding Log Viewer (Fuslogvw.exe):
https://msdn.microsoft.com/en-us/library/e74a18c4.aspx
Also make sure that's only one version of the assembly registered on the production server.
eddy.peng
But I don't have Fuslogvw.exe in my environment(Windows 2003, VB6), I use WINSCPnet.tlb in VB6 application.
What else can I check?
So download it. It's part of Windows SDK.
