Topic "TLS connection error/bug"
robbone
I'm trying to do a TLS connection using .NET library in C#, but I'm receivin a SSH error, it seems a bug.
Here my code:
SessionOptions sessionOptions = new SessionOptions();
                sessionOptions.HostName = _hostName;
                sessionOptions.Password = _password;
                sessionOptions.UserName = _userName;
                sessionOptions.Protocol = Protocol.Ftp;
                sessionOptions.FtpSecure = FtpSecure.Implicit;
                sessionOptions.PortNumber = 990;
                sessionOptions.FtpMode = FtpMode.Passive;
If I set:
sessionOptions.GiveUpSecurityAndAcceptAnyTlsHostCertificate = true;
I get the error:
System.ArgumentException: SessionOptions.SshHostKey or SessionOptions.GiveUpSecurityAndAcceptAnySshHostKey is set, but SessionOptions.Protocol is not Protocol.Sftp nor Protocol.Scp.
If I set:
sessionOptions.GiveUpSecurityAndAcceptAnySshHostKey
I get the same error above.
If I set:
sessionOptions.TlsHostCertificateFingerprint = "61:79:71...";
I get teh same error above, again
If I set
sessionOptions.SshHostKeyFingerprint = "61:79:71..."
I get the error:
System.ArgumentException: SSH host key fingerprint "61:79:71..." does not match pattern /((ssh-rsa|ssh-dss)( |-))?(\d+ )?([0-9a-f]{2}(:|-)){15}[0-9a-f]{2}(;((ssh-rsa|ssh-dss)( |-))?(\d+ )?([0-9a-f]{2}(:|-)){15}[0-9a-f]{2})*/
When I set TLS properties, the error says that I'm using SSH properties. So I believe it is a bug.
Can anyone help me?
I tested with versions 5.7.0 and 5.7.2
Here my code:
If I set:
I get the error:
If I set:
If I set:
If I set
I get the error:
Can anyone help me?
With this code, I'm not getting any exception:
sessionOptions.HostName = "localhost";
sessionOptions.Password = "test";
sessionOptions.UserName = "test";
using (Session session = CreateSession())
    session.Open(sessionOptions);
Neither with this code:
sessionOptions.TlsHostCertificateFingerprint = "a0:cd:69:37:d2:f6:d3:ee:a7:5d:39:3d:e7:5e:36:f4:9a:83:45:60";
Both with 5.7.2.
Please show us your exact complete code that produces the exception.
jyothi
SSHkey which is using in the code seems to wrong ,please Provide the correct key then this error will be gone
