Topic "winscp.com not returning the prompt"
gual61
Hallo,
I am doing somthing very simple: I have a batch upload.bat
winscp.com /script="upload.txt"
if %ERRORLEVEL% neq 0 goto error
echo Success
blat -body "OK" -subject "WinSCP Success" -to recipient@domain.tld
exit 0
:error
echo Error!
blat -body "FEHLER" -subject "WinSCP Fehler" -to recipient@domain.tld
exit 1
and the script file
# Automatically abort script on errors
option batch abort
# Connect to SFTP server using a password
open ftp://user:pass@domain.tld
# Upload new files
synchronize remote -criteria=time -transfer=binary -filemask=*.jpg D:\UPLOAD /IMAGES
# Disconnect
close
Basically, it works. The Problem is that winscp after execution won't return the prompt to the batch (it does not terminate) and batch processing stops.
I can not figure out what ist wrong.
Thank you in advance for help
You have to add an exit command.
