Topic "downloading specific folder"
dodger2015
Hi Guys,
Hope somebody can help, this has been bugging me for two days now.
ive searched through the posts concerning but each one gets me a little more confused.
I simply want to download a cpanel backup automatically to my home pc every day,
so far I have the script below which downloads everything in the backups folder but I want to just download the accounts folder.
My problem is one of the folder names changes to the current date every day.
ie:
/backup/2015-04-16/accounts
so the date part changes to the next day every day, and its just the accounts folder I want to download.
I believe this is what I need:
$stamp = $(Get-Date -f "yyyyMMdd")
but I cant get it to work what ever I do.
any ideas what I need to do would be appreciated, thank you.
option batch abort
open sftp://USERNAME:PASSWORD@0.0.0.0:34567
cd /backup
option transfer binary
get *.* C:\Users\homepc\Desktop\FTP-site-backups\
close
Dodger2015
Solved that problem with TIMESTAMP%%. Happy days Smile
I have a new problem now though.. Windows task manager still shows the task as running
After the files have all downloaded.. So the PC will not go to sleep because of this.
Has anyone come across this before?
Thank you.
You are missing exit command at the end of the script.
matrixtan
How can I download 3 files from the same folder. The file has a different date everyday i.e XXX_05082015. Need to download the file with T-2 workday. i.e XXX_05082015. What is the correct code to use?
Regards.
You can use a filemask with time-constraint:
http://winscp.net/eng/docs/file_mask#size_time
Like get *<2D>=3D = download all files newer than 3 days but older than 2 days.
