Topic "ResumeSupport.State does not seem to work."
icedteax
Hi, I'm uploading files on a sftp server using:
TransferOptions.ResumeSupport.State = TransferResumeSupportState.Off
After the upload, I try to compare the file size of the local / remote files to be sure everythings are right but when I list the files they have a stamp like this :
MyFile_186804232.txt instead of MyFile.txt. So I'm unable to match them correctly.
If I wait couple of seconds and I list the files again, they are named correctly.
I don't know what I'm doing wrong. Do you have an Idea?
The version is : 5.7.2
It's not WinSCP that's adding the numbers to the file name. It has to be the server or some server-side process.
icedteax
So is it the way I do it that is wrong?
When I want to upload files I do this:
Connect
Set TransferOptions
For each file
transferResult = PutFiles(....)
transferResult.Check
Next
-- I do not disconnect yet
-- In another function i do this
ListFiles
-- I verify I the listed files and sizes are the same as the local files I wanted to upload
-- If one or some files are not transferred correctly I create an Exception.
-- After I Disconnect Into my Upload function
My Question is: Am I ok to only use the transferResult.Check to be sure my upload is fine?
No. You are doing it right.
Correct.
