Topic "FTP sync files - file in use problem"
I need to sync local dir -> remote dir, and i use sync command to do it. Only problem is that if some file is in use its says:
"System Error. Code: 32.
The process cannot access the file because it is being used by another process"
It would be nice if sync can continue to next file but its not. Sync process stops every time when file in use error appears.
I'm using 5.7.2 b5316 (win-portable) version.
Couple links to same kind a problems: (says fixed in version 5.6 but exist 5.7.2 ?)
See Continue on error option:
