Topic "Sample Script to send files using SFTP WINSCP"
vk.kumar
Hi All,
Iam new to scripting. My requirement is as below:
Poll the files from a particular location and send to target location using SFTP (WINSCP).
Guide me writing a script for this requirement.
Thanks in Advance.
Krishna
What specific problem are you having with the task? Where are you polling the files from? A local or remote location?
vk.kumar
1. Files will be polled from local machine.
2. I need to transfer multiple files from local machine to remote SFTP location.
Could you provide sample script for the above requirement.
Just create a simple upload script and schedule it to run in regular intervals (or in a loop from a batch file).
See
http://winscp.net/eng/docs/guide_automation
http://winscp.net/eng/docs/guide_schedule
vk.kumar
Thanks for the update.
what should be given in the hostkey value.
open sftp://user:password@example.com/ -hostkey=""
Hema
If you are using 5.7.2. version, click 'Session' tab in the Menu, then click 'Server/Protocol Information'. 'Server host key fingerprint' can be seen at the bottom of the 'Protocol' screen.
vk.kumar
thanks for update.
we are using WINSCP 4.3.2 version. I couldn't able to find the option which you were telling.
do we need to give the private key in the hostkey value??.
Regards,
Kumar
See http://winscp.net/eng/docs/faq_hostkey
In 4.3.2, the command in is Commands menu.
Though you SHOULD NOT use 4.3.2. You need to upgrade!
