Topic "Cannot create remote file"
pmdrgl
Have installed WinSCP and keep coming up with the following error:
Permission denied.
Error code: 3
Error message from server: Permission denied
Have tried solutions from forums, but still producing this error.
Version of WinSCP you are using (you should be using the latest version if possible).
--5.7.2
Version of Microsoft Windows you are running WinSCP on.
-- Windows 7
Transfer protocol (SFTP, FTP, SCP or WebDAV).
-- SFTP
If you experience an error, include full error message. You may use Ctrl+C to copy the message, then paste it (Ctrl+V) to the post. Also check list of common error messages.
Cannot create remote file '/var/www/...' (I have obscured the file location)
Permission denied.
Error code: 3
Try to describe precise steps that lead to the problem (where do you click, what keys do you press, what do you see, etc.).
I can download files, but I cannot upload files. While not the owner, I am in a group with the same rights as the owners on the file - can read and write. Have tried other solutions seen on similar posts in the forum - modifying transfer settings, unchecking 'preserving timestamp', disabling transfer resume/transfer to temporary filename, but it still does not work for me.
If your problems relates to interaction with remote server, please post a full log file showing the problem.
-- See attached file
Fairly new to using this, so if any more info is required, let me know.
Thanks!
error-log.txt (5.62 KB) Private file
Description: (none)
To upload a new file, you need to have a write permissions to the containing folder. Have you?
I am in a group that has rights on all folders: rwxrwsr-x
Is this sufficient access?
pmdrgl
I have confirmed with a developer that I was not in the group with permissions for the folder I was trying to access. I am now and it works. Please mark as closed and thanks for looking into this.
ABCAbl
Reason: no space left on the server so just need to delete or transfer files
