Topic "Can't change server time zone settings"
countytime
My server is set to GMT, which is 4 hours ahead. I'd like to adjust that so I can use WinSCP's synchronize features, but the option in Advanced Site Settings is greyed out, like so:
How do I change that? (Or if there's some other change I can make so that synchronization works, that's fine too.)
So are you asking about DST (as per subject) or time-zone offset (as per text)?
In either case, see documentation:
http://winscp.net/eng/docs/ui_login_environment
It documents when the options are available.
countytime
Timezone offset, sorry.
countytime
Fixed, thanks.
What I actually had to do was go into the advanced site settings, and
1. Set MSLD to "off"
2. Uncheck "detect automatically" **but leave the difference at zero**. It was the detecting automatically that did it; simply turning that off fixed it. (When I manually subtracted 4 hours, it came out 4 hours early.)
countytime
Or not fixed =x What happens is it works on the very first change, uploads the new file, but when it appears on the server the timestamp is blank. Not just wrong, but blank. Then it stops uploading automatically. If I manually click an upload through, the timestamp reappears.
Can you attach a log file showing directory listing with default settings (MLSD on/auto)?
Mention what timestamp WinSCP shows for a certain file and what timestamp do you expect and why.
