Topic "Script only waits 9 seconds for a password to be entered"
ChrisB
I have a batch script that uses a connection entry from my ini file that does not have a password set. No matter what value I put in the /timeout setting, the script only waits 9 seconds before failing the connection. Is there any way I can make it wait a little longer for a user to input the password?
Script example:
C:\WinSCP\WinSCP /timeout=60 /command "option batch on" "option confirm off" "open MyFTPSConnection" "ls ""/Home/Test Directory/""" "close" "exit" /log=C:\WinSCP\test_LOG.xml
test_LOG.xml contents:
-<session start="2015-05-06T18:34:49.843Z" name="MyFTPSConnection" xmlns="http://winscp.net/schema/session/1.0">
-<failure>
<message>Connection failed.</message>
<message>Using TLSv1.2, cipher TLSv1/SSLv3: AES128-SHA256, 2048 bit RSA</message>
<message>PASS: parameters are incorrect</message>
</failure>
</session>
Any help is appreciated
It's actually not expected that the script requires any user interaction in batch on mode.
That's why there's 10 seconds timeout (it could actually abort straight away).
You can set batch off before the open command and enable the batch on mode only after.
ChrisB
EXACTLY what I needed. Thank you for your help and your product. Donations are on the way!
