Topic "rm *.csv not removing anything"
KeeghanM
I have a script which is downloading all the files from a folder onto my local machine. Then I want to remove everything from the remote folder. The script I have is:
option batch on
open SAMBA
cd /home/ftpadriley/VehicleAudit/
lcd C:\temp\VehicleAudit\Download\
mget *.csv
rm *.csv
Which works up till the rm *.csv line. I download all the files, but they stay up there.
I also tried a get -delete and that didn't work either.
I have permission to delete, my connection is set up with root.
thanks for any help,
Keeghan
KeeghanM
Uploaded the log file, when its doing the rm *.csv it is coming back "Status Code: 0" which indicates that it is working, however I can confirm 100% that the files are still in the folder that its apparently deleting from.
thanks for any help.
Keeghan
log_file.txt (123.49 KB) [Download]
Description: (none)
You can see in the log file that deleting of about 60 .csv files was requested by WinSCP and confirmed by the server (with no error). If the files were not deleted by the server actually, it's not a problem of WinSCP.
