Topic "Prooblem adding filemask to my script"
Honky
Hi Winscp Guru's,
my Script works very nice but now i would like to add an filemask to transfer only files older than 5minutes.
Do you an idea how set this in my script?
param (
    $localPath = "F:\Test-Sync01\",
    $remotePath = "/Test-Sync01/"
try
    # Load WinSCP .NET assembly
    Add-Type -Path "F:\syncapp\WinSCPnet.dll"
    # Setup session options
    $sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
    $sessionOptions.HostName = "server08"
    $sessionOptions.UserName = "syncusr"
    $sessionOptions.Password  = "BLBALBLA"
    $sessionOptions.SshHostKeyFingerprint = "ssh-rsa 1024 13:d3:ef:ee:4d:cc:22:31:04:aa:1e:cd:7b:c7:42:02"
    try
        # Connect
        $transferOptions.FileMask = "*<5N"
        # Synchronize files to local directory, collect results
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Remote, $localPath, $remotePath, $False, transferOptions)
        # Iterate over every download
        foreach ($download in $synchronizationResult.Uploads)
            echo $download.FileName
            # Success or error?
            if ($download.Error -eq $Null)
                Write-Host ("Download of {0} succeeded, removing from source" -f
                    $download.FileName)
                try
                    Remove-Item $session.EscapeFileMask($download.FileName)
                    Write-Host ("Removing of file {0} succeeded" -f
                        $download.FileName)
                catch [Exception]
                    Write-Host ("Rmoving of file {0} failed" -f
                        $download.FileName)
            else
                Write-Host ("Download of {0} failed: {1}" -f
                    $download.FileName, $download.Error.Message)
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host $_.Exception.Message
    exit 1
Honky
anybody ?!?, please. Smile
Use TransferOptions.FileMask
http://winscp.net/eng/docs/library_transferoptions
http://winscp.net/eng/docs/file_mask
The mask will be like: <5N
Honky
Hi prikryl,
thanks for your reply. I readed this sites before.
But my Script ignores any TransferOptions. Do you have any idea in which line the problem could be?
Show us your code with TransferOptions.
Honky
Thanks,i added the tranferoptions in the upper script.
You are passing the transferOptions to mirror parameter of SynchronizeDirectories and you are missing $.
It should be:
[WinSCP.SynchronizationMode]::Remote, $localPath, $remotePath, $False, $False, $transferOptions
