Topic "Open session and log connection details"
dvd.ribeiro
Hi all, I'm trying to troubleshoot a session opening which gives me the following error:
"Message: Terminated by user.
at WinSCP.SessionLogReader.Read(LogReadFlags flags)
at WinSCP.SessionElementLogReader.Read(LogReadFlags flags)
at WinSCP.CustomLogReader.WaitForNonEmptyElementAndCreateLogReader(String localName, LogReadFlags flags)
at WinSCP.Session.Open(SessionOptions sessionOptions)"
The code I'm running is the following:
SessionOptions sessionOptions = new SessionOptions();
                    sessionOptions.Protocol = Protocol.Sftp;
                    sessionOptions.HostName = "sftp.stuff.com";
                    sessionOptions.UserName = "username";
                    sessionOptions.Password = "password";
                    sessionOptions.GiveUpSecurityAndAcceptAnySshHostKey = true;
                        session.Open(sessionOptions);
                        TransferOptions transferOptions = new TransferOptions();
                        transferOptions.TransferMode = TransferMode.Binary;
                        transferOptions.PreserveTimestamp = false;
                        TransferOperationResult transferResult;
                        transferResult = session.PutFiles("C:\localfile.txt", "sftp.stuff.com/remotepath/remotefile.txt", false, transferOptions);
                        transferResult.Check();
Am I missing something here?
I believe that enclosing all code inside using it closes and disposes the connection.
After this error I was able to upload files to server correctly. is there any way to enable and use WinScp logging to trace connection issues?
Thank you.
dvd.ribeiro
Found out how to track session details:
                            session.SessionLogPath = "Your full file Path here";
Did it help you to resolve the problem?
