Topic "Secured Password in Powershell Script"
Honky
Hello WinSCP Guru's,
is there any possibility to use an encrypted password (like in the GUI)in the my Powershell-Script?
param (
    $localPath = "F:\Test-Sync01\",
    $remotePath = "/Test-Sync01/"
try
    # Load WinSCP .NET assembly
    Add-Type -Path "F:\syncapp\WinSCPnet.dll"
    # Setup session options
    $sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
    $sessionOptions.HostName = "server08"
    $sessionOptions.UserName = "syncusr"
    $sessionOptions.Password  = "BLBALBLA"
    $sessionOptions.SshHostKeyFingerprint = "ssh-rsa 1024 13:d3:ef:ee:4d:cc:22:31:04:aa:1e:cd:7b:c7:42:02"
    try
        # Connect
        # Synchronize files to local directory, collect results
        $synchronizationResult = $session.SynchronizeDirectories(
            [WinSCP.SynchronizationMode]::Remote, $localPath, $remotePath, $False)
        # Iterate over every download
        foreach ($download in $synchronizationResult.Uploads)
            echo $download.FileName
            # Success or error?
            if ($download.Error -eq $Null)
                Write-Host ("Download of {0} succeeded, removing from source" -f
                    $download.FileName)
                try
                    Remove-Item $session.EscapeFileMask($download.FileName)
                    Write-Host ("Removing of file {0} succeeded" -f
                        $download.FileName)
                catch [Exception]
                    Write-Host ("Rmoving of file {0} failed" -f
                        $download.FileName)
            else
                Write-Host ("Download of {0} failed: {1}" -f
                    $download.FileName, $download.Error.Message)
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host $_.Exception.Message
    exit 1
Thanks in advance!
Honky
found it:
1. Generate Hash in Powershell:
Read-Host 'Enter password' -AsSecureString |
ConvertFrom-SecureString |
Out-File 'C:\password.txt'
2. Copy/Paste Hash from password.txt
3. Replace
$sessionOptions.Password = "BLBALBLBA"
with
$sessionOptions.SecurePassword = ConvertTo-SecureString "01000000d08c9ddf0115d1118c7a00c04fc297eb01000000d5e66e657ce0264d9cdffd82e583fec00000000002000000000003660000c00000001000000005351f863d78e0364289ed60022d65a30000000004800000a000000010000000467b753a60f8a4ef0b612880c92ec6c730000000b87f47ffd9c5bafbc1a2a3d39e520199e8b10cb571aa97cd9ec2c43b86fed4fb0c1e40d3b5fc81ecc04dd79f1f71f942140000001c829482c76164fa43e7af395ff2ca3db611821b"
Thanks for sharing your solution.
