Topic "Can't get attributes of file"
john523
I am having issues using the $session.GetFileInfo in powershell, and I keep getting the error "Can't get attributes of file." I am actually trying to download the file. Uploading works fine, but not downloading. Below is the logfile:
Any help would be appreciated.
2015-05-15 17:38:08.322 --------------------------------------------------------------------------
. 2015-05-15 17:38:08.322 WinSCP Version 5.7.2 (Build 5316) (OS 6.1.7601 Service Pack 1 - Windows 7 Professional)
. 2015-05-15 17:38:08.322 Configuration: nul
. 2015-05-15 17:38:08.322 Log level: Normal
. 2015-05-15 17:38:08.323 Time zone: Current: GMT-7 (US Mountain Standard Time), No DST
. 2015-05-15 17:38:08.323 Login time: Friday, May 15, 2015 5:38:08 PM
. 2015-05-15 17:38:08.323 --------------------------------------------------------------------------
. 2015-05-15 17:38:08.323 Script: Retrospectively logging previous script records:
> 2015-05-15 17:38:08.323 Script: option batch on
< 2015-05-15 17:38:08.323 Script: batch on
< 2015-05-15 17:38:08.323 Script: reconnecttime 120
> 2015-05-15 17:38:08.323 Script: option confirm off
< 2015-05-15 17:38:08.323 Script: confirm off
> 2015-05-15 17:38:08.323 Script: option reconnecttime 120
> 2015-05-15 17:38:08.323 Script: open ftp://rejuva:***@ftp.jaygroup.com:21 -passive=1 -timeout=15
. 2015-05-15 17:38:08.323 Session name: (Ad-Hoc site)
. 2015-05-15 17:38:08.323 Host name: (Port: 21)
. 2015-05-15 17:38:08.323 User name: (Password: Yes, Key file: No)
. 2015-05-15 17:38:08.323 Transfer Protocol: FTP
. 2015-05-15 17:38:08.323 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2015-05-15 17:38:08.323 Disable Nagle: No
. 2015-05-15 17:38:08.323 Proxy: none
. 2015-05-15 17:38:08.323 Send buffer: 262144
. 2015-05-15 17:38:08.323 UTF: 2
. 2015-05-15 17:38:08.323 FTP: FTPS: None; Passive: Yes [Force IP: A]; MLSD: A [List all: A]
. 2015-05-15 17:38:08.323 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2015-05-15 17:38:08.323 Cache directory changes: Yes, Permanent: Yes
. 2015-05-15 17:38:08.323 Timezone offset: 0h 0m
. 2015-05-15 17:38:08.325 Connecting to ...
. 2015-05-15 17:38:08.435 Connected with . Waiting for welcome message...
< 2015-05-15 17:38:08.533 220 X2 WS_FTP Server 7.0(87395757)
> 2015-05-15 17:38:08.533 USER
< 2015-05-15 17:38:08.643 331 Enter password
> 2015-05-15 17:38:08.643 PASS ********
< 2015-05-15 17:38:09.035 230 User logged in
> 2015-05-15 17:38:09.035 SYST
< 2015-05-15 17:38:09.154 215 UNIX
> 2015-05-15 17:38:09.154 FEAT
< 2015-05-15 17:38:09.262 211-Extensions supported
< 2015-05-15 17:38:09.262 SIZE
< 2015-05-15 17:38:09.262 XMD5
< 2015-05-15 17:38:09.262 XSHA1
< 2015-05-15 17:38:09.262 XSHA256
< 2015-05-15 17:38:09.262 XSHA512
< 2015-05-15 17:38:09.262 XQUOTA
< 2015-05-15 17:38:09.262 LANG EN, ES, FR, GE
< 2015-05-15 17:38:09.262 MDTM
< 2015-05-15 17:38:09.262 MLST size*;type*;perm*;create*;modify*;
< 2015-05-15 17:38:09.262 REST STREAM
< 2015-05-15 17:38:09.262 TVFS
< 2015-05-15 17:38:09.262 UTF8
< 2015-05-15 17:38:09.262 AUTH SSL;TLS-P;
< 2015-05-15 17:38:09.262 PBSZ
< 2015-05-15 17:38:09.262 PROT C;P;
< 2015-05-15 17:38:09.262 211 end
> 2015-05-15 17:38:09.262 OPTS UTF8 ON
< 2015-05-15 17:38:09.357 200 Command OPTS succeed
. 2015-05-15 17:38:09.357 Connected
. 2015-05-15 17:38:09.357 --------------------------------------------------------------------------
. 2015-05-15 17:38:09.357 Using FTP protocol.
. 2015-05-15 17:38:09.358 Doing startup conversation with host.
> 2015-05-15 17:38:09.358 PWD
< 2015-05-15 17:38:09.454 257 "/" is current directory
. 2015-05-15 17:38:09.454 Getting current directory name.
. 2015-05-15 17:38:09.454 Startup conversation with host finished.
< 2015-05-15 17:38:09.455 Script: Active session: [1]
> 2015-05-15 17:38:09.746 Script: pwd
< 2015-05-15 17:38:09.746 Script: /
> 2015-05-15 17:38:09.874 Script: ls -- "/Test/ShipConfirm/"
. 2015-05-15 17:38:09.874 Retrieving directory listing...
> 2015-05-15 17:38:09.874 CWD /Test/ShipConfirm/
< 2015-05-15 17:38:10.025 250 Command CWD succeed
> 2015-05-15 17:38:10.025 PWD
< 2015-05-15 17:38:10.130 257 "/Test/ShipConfirm" is current directory
> 2015-05-15 17:38:10.130 TYPE A
< 2015-05-15 17:38:10.233 200 Transfer mode set to ASCII
> 2015-05-15 17:38:10.233 PASV
< 2015-05-15 17:38:10.349 227 Entering Passive Mode
> 2015-05-15 17:38:10.349 MLSD
. 2015-05-15 17:38:10.349 Connecting to
< 2015-05-15 17:38:10.567 125 Transferring directory
< 2015-05-15 17:38:10.598 226 Transfer completed
. 2015-05-15 17:38:10.603 size=0;type=cdir;create=20150506111215;modify=20150515193636; .
. 2015-05-15 17:38:10.603 size=0;type=pdir;create=20150506111201;modify=20150506111215; ..
. 2015-05-15 17:38:10.603 size=0;type=dir;create=20150515141324;modify=20150515141324; Archived
. 2015-05-15 17:38:10.603 size=12810;type=file;create=20150515123039;modify=20150515123039; Confirm_20150515_122949.TXT
. 2015-05-15 17:38:10.603 size=34366;type=file;create=20150515141345;modify=20150515141347; Confirm_20150515_125002.CSV
. 2015-05-15 17:38:10.603 size=14;type=file;create=20150515193636;modify=20150515193636; test.txt
. 2015-05-15 17:38:10.603 Directory listing successful
. 2015-05-15 17:38:10.603 ..;D;0;1899-12-30T07:00:00.000Z;"" [0];"" [0];---------;0
. 2015-05-15 17:38:10.603 Archived;D;0;2015-05-15T14:13:24.000Z;"" [0];"" [0];---------;0
. 2015-05-15 17:38:10.604 Confirm_20150515_122949.TXT;-;12810;2015-05-15T12:30:39.000Z;"" [0];"" [0];---------;0
. 2015-05-15 17:38:10.604 Confirm_20150515_125002.CSV;-;34366;2015-05-15T14:13:47.000Z;"" [0];"" [0];---------;0
. 2015-05-15 17:38:10.604 test.txt;-;14;2015-05-15T19:36:36.000Z;"" [0];"" [0];---------;0
< 2015-05-15 17:38:10.604 Script: D--------- 0 0 ..
< 2015-05-15 17:38:10.604 Script: D--------- 0 0 May 15 7:13:24 2015 Archived
< 2015-05-15 17:38:10.604 Script: ---------- 0 12810 May 15 5:30:39 2015 Confirm_20150515_122949.TXT
< 2015-05-15 17:38:10.604 Script: ---------- 0 34366 May 15 7:13:47 2015 Confirm_20150515_125002.CSV
< 2015-05-15 17:38:10.604 Script: ---------- 0 14 May 15 12:36:36 2015 test.txt
> 2015-05-15 17:38:10.943 Script: stat -- "test.txt"
. 2015-05-15 17:38:10.943 Listing file "test.txt".
. 2015-05-15 17:38:10.943 Retrieving file information...
> 2015-05-15 17:38:10.943 MLST /test.txt
< 2015-05-15 17:38:11.062 550 Permission denied
. 2015-05-15 17:38:11.062 Could not retrieve file information
< 2015-05-15 17:38:11.062 Script: Can't get attributes of file 'test.txt'.
< 2015-05-15 17:38:11.062 Script: Could not retrieve file information
< 2015-05-15 17:38:11.062 Permission denied
. 2015-05-15 17:38:11.062 Script: Failed
> 2015-05-15 17:38:11.074 Script: exit
. 2015-05-15 17:38:11.074 Script: Exit code: 1
. 2015-05-15 17:38:11.075 Disconnected from server
Can you show us your PowerShell code? I assume you are not passing a full path to Session.GetFileInfo, just a file name.
